My new problem is that the gussets are tilting my walls.
If I brace my wall studs perfectly vertical, then Weld a gusset in place, the entire gussets goes up by a few hundred degrees and expands.
Since the wall is being held vertical, the molten edges of the gussets are squishing shorter as I Weld, and when things cool down, they pull the tops of my walls inward by somewhere between a half inch and a full inch.
The hard part is that the exact change in length of the gussets are determined by the temperature the gusset got up to during that SPECIFIC Weld.
I've been welding gussets, checking how out of plum my wall stud got, using a cutting disk to cut straight through the center of the Weld, then hammering a wedge into the gap to push the wall slightly out of vertical in the opposite direction, then bridge welding the gap, pulling the wedge, and seeing how close to vertical I've got.
(Wow, that's a run-on sentence)
Some of my Welds now look super wide because they're actually 3 Welds done one atop the other.
This seemingly simple part of the project is taking WAAAYYY too much time!
