WendellNV
Advanced Member
My plans are to build a light weight “Canned Ham” style “standy” that will pull easily behind a mid size suv/crossover. We currently have a Subaru Tribeca that is rated to tow 1,000 lbs w/o trailer brakes/3,500 lbs with.
Hoping to hear from anyone who has some experience using cedar as siding.
Concerning siding, I want to use cedar fence pickets on the sides and the flat surfaces on the front and rear to create a unique look. The roof (and most likely the front and rear radiuses) would be 1/4” plywood with PMF or fiberglass mat and epoxy. I may try to cover the radiuses, front and rear with cedar siding, but not sure if it is a good idea.
There is a YouTube channel call ENDGAME where there are videos showing slide in truck campers built using cedar fence pickets for framing as well as siding. There are some pictures online, but not sure how to add them to this post. Tried, but got an error message.
My concern is that a travel trailer may flex more then a truck camper and without solid sheeting, the integrity of the structure may suffer.
The idea is to plane the pickets to 1/2”, true up the long edges, rip them to a standard dimension, dado the long edges and short edges as needed, to create a ship lap siding.
Install directly to the framing using construction adhesive or Titebond II, nailing and/or screwing boards in place to help secure siding. Also apply flexible caulking at the dados to help make the lap joints water resistant.
After installation, apply a wood sealer and reapply yearly or as needed.
Any thoughts, ideas or comments appreciated!
Regards
Regards
