Members explored ways to replicate the rugged, textured look of bedliner using regular latex paint on a fiberglass and epoxy camper. Suggestions included mixing play sand into paint for a gritty finish, though this method can be rougher than desired for walls and roofs. Others recommended using textured rollers with thickened paint, noting that while this technique is common for interior walls, it may require specialized additives for exterior durability.
Some RVers pointed out that...
More...
Some RVers pointed out that textured finishes are often achieved in homes with thickened latex paint, which can be sprayed or rolled on, and suggested consulting hardware stores for suitable products. One member proposed testing a layer of Titebond II glue applied with a thick roller before painting to add texture. Overall, while several DIY options exist, the consensus leaned toward using actual bedliner for best results, especially regarding adhesion and longevity on exterior surfaces.
