Bob Henry's 4x7
bobhenry-TNT
Senior Member
Joined
Feb 9, 2007
Posts
10,377
Well here I go again. I seem to have trouble finishing anything but have no problem at all starting another trailer.
The Chuck wagon has a little sister taking shape. Monday was a voulnteer day at work and a few of the guys wanted the hours so I unlocked the shop for them and did a little personal work.
Found a rather badly cupped 2x12 that was beautifully grained and knot free in the cull pile of "junk" lumber. I took this 14' er and cut two 3 inch wide boards from each side. I cut them into a 4' 3" and two 8 footers. I cut a rabbet 3/4 x 3/4 out of one edge. These 3 boards will surround a 4x8 sheet of 3/4 plywood that will become the floor of my little 4x7'6" sleeper trailer.
All the remaining material was cut into 1 1/2 x 1 1/2 spars. a little over 4 foot long.
Not officially working and the shop off and running when the boss came in I took my newly cut toys and headed home leaving him at the helm.
Arriving home I fitted the 3 rabbetted pieces aroung the 4x8 sheet and glued and screwed the frame around the floor for extra strength. I miter cut the adgoining edges for a neater look. I had 2 4x8 sheets of zip wall , a fiberglass faced 7 /16 osb, to cut the sides from .This is neat stuff. I made a 2 foot and 4 foot compass out of a long piece of flat trim. I marked a center at 2 foot down the 4 foot direction and 2 foot back the 8 foot way this was the center point for my 2 foot radius and marked from 12 o clock to 3 oclock I measured back 2 more feet and placed a center at 2 foot down and 4 foot back (the exact center of the 4x8 sheet)for the center of the 4 foot radius from 3 o clock to the bottom edge of the sheet.
I tried several methods to rig up a 11 foot radius from tail to the 12 oclock mark (2' back on the very top edge. Nothing was working. I finally found a slender piece of trim that would bend from the tail edge to the top point and bent it into place. I had ol what's her name pencil in the line for me as I had my hands full trying to keep the trim bent properly and in place.
Profile now scribed on the sheet I placed the other sheet underneth and screwed them together in the scrap areas to keep the edges aligned. I started the slow process of jig sawing out the profile. During the cut the saw became all but impossible to keep on the line. I knew what was wrong and immediatly installed another new blade and the problem was gone. With the sides cut out I had my buddy Jim to help me support the walls while I glued and screwed them to the 2x4 floor halo. I used the scrap from the 2 foot radii cuts to square and stabilize the walls and after taking cafeful measurements and doing a bit of math I cut a couple temporary spars to support the walls. I cut down some 6" foam to fit the floor and had my neighbor Tom help me remove the saw horses and place the shell on the ground. At about 11:30 last night ol what's her name and I test fit 2 old fat people in a 4' by 7'6" teardrop to see if we can sleep in there comfortably. It passed the test ! So ends the 1st
5 hours of the build.
Stayed after work about 45 minutes and cut the rabbets for the spars.
I always cut a 1 1/2 wide by 3/4" deep notch in the side and set the 3/4 deep by 1 1/2 wide rabbet in the side panel. There is no twisting and there is a bit more glue surface.
Arrived home and hot as **** so I had dinner and cooled down. About an hour before sun went down I went outside and cut the notches in the side panels and glued and screwed in the spars. It took about 2 hours because my new neighbor wandered over and was playing 20 questions and HAD to see the Barn and Chubby. So a 10 minute tour and a 45 minute Q & A session and I got 8 of the 11 spars in before it got too dark to work safely. Total actual working time 45 minutes to an hour plus the 45 minutes at work. Work time to date 6 1/2 hours.
:) :thinking: :NC :pictures: :pictures: :pictures:
YES. This thread is useless without pics. :LOL:
Except, of course, for your description of the salvage of that nicely-grained 14' stick!
Excuse me; I should go work on my IRG wagon... :oops:
What a demanding bunch :shock:
And ol' what's her name had the camera with her and got home late. :(
I sorry ! :roll:
OK ! Up at 5:00 and snapping pics at 5:45 am.
Here are a few.
This is only about 6+ hours into the project so progress is a little limited but it is starting to look like a teardrop.
Profile pic looks a bit funny because it is not setting level but it was do to rain today so I lifted the front so the water would shed off. Used the fence post treat on the 3/4 floor on all sides
image.php
I let the rear run long and decided to radius cut the rear.
What do ya think ?
image.php
Here is an end shot of the rabbet I was describing in an earlier post
image.php
Obviously a shot of the spars.
image.php
Here is how they attach. A lot of glue and one 3" construction screw angled up into the spar so it will travel cross grain. They run a fuzz long and will be sanded flush with the side later on.
image.php
Here is a closeup of the spar rabbets. They are supposed to be 3/4" deep this one looks a bit deeper.
image.php
Here is the little 4x7 I purchased abandoned and ignored in a back yard. I just walked up and knocked and $60.00 later I hooked it up and took it home.
image.php
It has an all aluminum bed and weighs 195 pounds total.
image.php
:LOL: :thumbsup: ;) Looking good so far! The lil trailer looks like in need some love! I sure hope that is not a 2"x4" I see... 8) Keep up the good work and let us know how the panels work; especially if they give off fumes. :thinking:
No that is not a 2x4 in the frame pic. It is a 2" x 2" fold of
heavy wall aluminum rivited to the aluminum pan floor as
reinforcing ribs. Why they chose to use the mild steel clip
on the end I don't know.
image.php
You were right about it needing a little lovin'
all new bearings and seals had to be installed and the
dust caps were missing and needed to be replaced,
Tires are "tired" and will also be replaced soon
I'll get it with the sander when I sand down the spars.
At this rate I should be able to drag it over to your place
for approval very soon ! :LOL:
Sounds good....approval from a 'yet to build'... :shock: oh wait you mean the cook's approval... :thumbsup:
By the way,I like the extra recurve on the tail.
Well at 6:10 the body went onto the frame. Somehow it fits like a glove.
The trailer measures 94" nose to tail with a fuzz over 7' on the floor.
Measuring from nose to axle I get 55 inches from axle to rear 39"
so I am about 59% forward and 41% rear and I was shooting for 60 / 40 I guess I can live with it :LOL:
It rolls 4 - 6 bolts and I can take it for a spin :twisted:
We will have to have a road test. Put a small cabinet in the rear nothing fancy just a good place for a simple electrical chase and some storage.
It is finally temporaly covered with a tarp and out of the rain.
I know pics , pics maybe in the AM been the day from **** I an gonna celebrate with a few barley pops and chill out.
BUT IT'S MOBILE :p
Bob Henry, you are the original mad man. I like it!! :LOL:
Look forward to the rest and seeing what the little dude weighs.
Here is the AM pics as promised.....
image.php
This trim piece was in the way so I ground off 2
dozen pop rivets to get it off the floor pan
:roll:
image.php
and it came off :shock:
image.php
and so did the pan :shock:
image.php
These little flip things flip up and down like a
real light weight tailgate hinge. Anyone have
a clue what this little trailer was in it's former
life
? :thinking:
image.php
a quick hit with the grinder and it was
gone what ever it was
image.php
Here is the underside , note the single u bolt around
the axle on each side . It shocked me a bit too !
image.php
Here is the rear profile with the rounded return.
The box is up on blocks ready to slide the trailer under.
image.php
Here is that rear cabinet. The roof will make the back
wall and the solid vertical panel in the pic will be cut
out for 2 cabinet doors or maybe a slider.
Yes the shelf is sagging 1x2's will be added
underneath to act as strongbacks for the shelf.
Bob, I wonder if it was one of those mini tent trailers?
The deck looks like aluminum? Perfect for what you're doing. :thumbsup:
It is aluminum sheeting with 3 heavy wall aluminum ribs as seen in the pics. I think the aluminum pan (shown removed) was the floor of what ever was on on top. Maybe a mini flop out motorcycle type camper. But why the front AND rear hinges for mini tailgates. They are ultra light and would not hold any amount of weight. There were also spring loaded to snap back up. The old gal I bought it off of had no clue what it was originally. It was just the hubbys junk hauler before he passed on.
I think my 195 pound frame is now down to #180. :)
The box is on and it will go for a cruise yet this evening.
New posts
