Bob's caboose build
Yes they are spruce pine fir cut offs. It is just the 1x4 and 1x6 you would get at the lumber yard. They will be places face grain not end grain and yes the finish will be the key.
I spent part of my weekend cutting the blocks to a true 5 1/2 x 5 1/2 as most were close to 6" +/- long. I have just under 300 of the 900+/- I need. I like free I am cheap and I think this will be a great looking and performing floor. A few well placed throw rugs to catch the incoming dirt and abrasive sand and I think it will prove to be a fairly durable material.
If not it can be another layer or I can remove it and start over.
I hope to take a 4x4 piece of plywood and adhere a few dozen tiles and make a trial piece to test a few Grouts. I really feel the grout lines are necessary first to keep the lines running square and to act as a sacrificial break point if the floor should flex.
I really should have cut the rest of my roof trusses this week but played with the floor instead. I guess it makes since in building to start at the bottom and work up :lol:
Don't know why it wouldn't work Bob, can't be any softer than linoleum.
You can always refinish it when it gets scratched up. Linoleum, well ... :roll:
I am wanting a baggage door on the caboose build. This is a good representation of the look.........
image.php
With perhaps this style of roller system ........
image.php
It will be a 42 to 48 inch wide "pocket" door my questions are how to construct and is there a better roller hardware for a larger and heavier than normal pocket door hardware.
Obviously thermal integrity and water intrusion are my two greatest worries.
The side wall forward of the baggage door in the picture is the bathroom on the donor trailer. That wall could be framed as 2x8 or 2 x 10 if needed to house the door. Latching hardware is another ??? in my mind. Maybe it's time to get to a couple railroad museums and look around .
Hi Bob,
Unless you desire the look of the rolling hardware [and since you seem
to be receptive to novel solutions] let me throw out a suggestion.
I've always thought a home-built solution for a sliding door could go as
follows:
Use a very hard hardwood for top and bottom runners and dado a centered
groove in them. In the bottom groove 2+ urethane wheels [depending on
the width of the door] would ride. [The taller, thinner kind like those used
on skateboards etc..] These wheels would be mounted in the bottom door
frame using small inset U brackets you would screw/bolt to the door and which
would carry the small 'axle' the urethane wheels would need. I'm
assuming the door is thick enough to allow for the urethane wheel's
and axle bolt head and nut. A thin skirt of 1/4 x 3-4in poplar or a door
protector type metal panel could also be used to skirt it. The top could
be handled similarly or you could mount a tall or squatty ['technical term'
Ha!] urethane wheel, who's diameter is just a small bit larger than the door
thickness, perpendicular to the door faces on top that could
locate the door top in a deeper corresponding groove or a U shaped top channel that
could be made by assembling one out of hard close grained hardwood 1x
for the top of the door to ride in.
Top and bottom side sealing could be done with the brass spring and/or
brush type weatherstripping and the vertical ends could use interlocking or
doubled up rubber type weatherstripping mounted on small wood/metal
flanges attached to the door sides and walls etc..
I'd also recommend to build the door yourself with a perimeter frame and
foam center and ply skins [or maybe aluminum ?] It'd be lighter and have
the insulation factor since it would be such a large amount of the sidewall
area. I'm sure you could make it look authentic easily enough.
Have fun devising your solution.
Norm/mezmo
Sounds to me like you're re-inventing the sliding glass patio door on many houses now. I know you aren't thinking glass, but the rest of the hardware is already invented. You just want to put in a panel instead of glass, and have it slide into a pocket. Easy-peasy.
8)
Catherine
8)
Catherine
As Homer says so often DUH !
I work next door to a glass shop and about once a month there is a patio door in the in the junk pile. Generally the glazing gasket has failed and the fogged window is the reason for replacement. Remove the glazing and fill with blue foam adding nailers where needed. Skins can be attached by drilling the aluminum frame and with a bit of wood moldings added it could become a rather authentic RR door. A little work with casings and trim and I may be able to hide the Aluminum look completely.
:thumbsup: BRILLIANT
Sometimes we overlook the obvious :oops:
Norm:
I was using the old steel skate wheels in my head but the new age plastic is a great idea as rollers.
I was born too soon my skate board actually had metal wheels
:lol:
Went and played with paint a bit to draw up this.
The four little windows at the top I still have from the 4x7 build that I decided not to use.
image.php
The outer halo casing is 1x3 hardwood as is the center horizontal rub board. This would cover the skin and help to guide the door into the wall pocket.
Add a little fancy moldings around the windows and make mock panels below and this is kinda sorta the idea :thumbsup:
image.php
Bob, I used garage door tracks and wheels to make sliders for my screen porch. No problems after six years.
Thought you might get a kick out of my local Freecycle ad.
ISO DAMAGED PATIO DOOR
Posted by: "bobhenryhenrybob" [email protected] bobhenryhenrybob
Tue Feb 7, 2012 9:25 am (PST)
I AM IN SEARCH OF A TAKE OUT PATIO DOOR 6 FOOT OR WIDER THE
GLASS WILL BE REMOVED SO I DON'T CARE ABOUT THE GLAZING
CONDITION BUT DO NEED A COMPLETE FRAME. STANDING OUTSIDE
THE RIGHT PANEL SHOULD BE THE ACTIVE( MOVABLE) PANEL.
Yep cheap is good and FREE is even better ! :thumbsup:
Tiny house design thoughts.....
Wandering the house last night taking inventory of what to take with me on my next adventure in life, tiny house living.
I spied my collection of old blue/green Ball canning jars. They have been doing little but holding down a couple of shelves and drawing dust. I picked up one and measured it. The Quarts are just a fuzz under 4" in diameter. So I got out the ruler and drew a 2x8 ( 1 1/2 x 7 1/4 ) studded wall full scale from stud to stud 24" on center.
It works out to 5 jars fitting in the 22 1/2" between face of stud to face of stud. So if the wall studs immediatly behind the kitchen counter were increased to 2x8's from the 2x3's I planned on using I will have just created a hugh shallow pantry. The 4.5 added inches of wall depth for 8 feet is about 3 sq ft of floor space lost but it was traded for 16 cubic feet ( 4' tall by 8' wide by 6" +/- deep ) of usable storage in the wall. I am allowing for a 3/4 layer of blue foam insulation being added in the back of each cavity. Possibly not the most effecient "R" rating but now by adding cabinet doors it might be a good trade off. What do you need 20 jars for you ask !
Well I tried to think.... :thinking:
Maybe a couple types of dried beans 2 or 3 styles of pastas. Sugar, flour, corn starch, coffee, corn meal, Hot cocoa mix Well there is not quite a dozen of them filled without any real creative thought.
I might just lean towards a simple galley rail to keep them in place at first and some 12 volt LED strip lighting to back light them and they might just be a real nice decorating touch with an old timey flair.
image.php
image.php
This picture just triggered another design idea.
The pitcher pump in this picture really works. It draws from a 12 gallon tank under the counter that is refilled with city water and controlled by a cattle float shut off valve. ( Kinda like the guts in an old style toilet )
Well I think it will get a new life in the caboose. No electricity required no need for city water pressure. These things just have a way of finding me !
Mocked up the wood block floor tiles. Here are a few pics
image.php
image.php
Raw block on block verses running bond look ?? What do you think?
image.php
image.php
After I added the color I was really liking the block on block.
A couple coats of some old poly I had lying around and it is soooo shiney. :thumbsup:
I don't know why it's not showing up but I looked in your album and Wow it is looking really good. I like the checkered pattern as well as the thriftiness the fact that your recycling and lowering your carbon-foot print for this trailer is an added bonus. You are a very good craftsman with a very creative mind. Thanks for being such an inspiration to all of us :applause: :applause: :applause: :applause: :applause:
The secret is to paste the Image-URL, and put img tags around that!
see here:
image.php
Hi Bob,
When you go to install the floor, try laying it out on the diagonal to see if
you like it. That is supposed to make a narrow space look/appear wider
and I think that's true. But it's all in the look you want for personal
satisfaction.
Norm/mezmo
Well I had that one bass akwards.....
A stacked pattern can accentuate the linear qualities of the room. Stacked tile can draw the eye from wall-to-wall, A diagonal pattern can open things up a bit. Diagonal can fool the eye into thinking a narrow room is less narrow, for example, by drawing the eye from corner-to-corner, which is a longer distance than wall-to-wall
I was thinking the long straight lines would fool the eye into thinking things would appear larger and longer than they actually were.
Thanks Norm :beer:
