Bob's caboose build
Was wandering around on the internet and tripped over this........
image.php
A simple loft mounted gravity feed water tank.
and this nifty little stealth kitchen
image.php
image.php
Got serious this weekend and cut 26 roof truss patterns. These will be doubled up in pairs with 2x2 fillers inside to give the caboose that rounded roof. I also cut a barrell vault on the underside to give a little interest and a bit more headroom. Here are a few shots of the work......
image.php
birds eye view of the radius cutting system :D
image.php
here is a finished end truss without the barrell vault
image.php
My giant flyswatter :laughter:
image.php
here is a barrell vault truss
image.php
There were 20 pieces of these as scrap. I thought, what a neat rounded roof truss for a teardrop. They happened to be 5'3" wide
image.php
Here is my free trash picked door. Will go on the platform end of the caboose for an entry door
image.php
They were even kind enough to leave me the dead bolt key :thumbsup:
image.php
Exterior side is a bit sun burnt but a little lovin' with sandpaper and varnish and it will be lookin' good again.
Here is a rough drawing of the nonstandard framing of the caboose roof and wall connection............
image.php
My fear was incorporating a hinge point at a standard top plate by just setting the truss on the sidewalls.
With only one cross wall at the bathroom end this could have become a wiggley little shack. To eliminate the hinge point and relying on just the nails for attachment I chose to glue and screw the roof trusses to the wall studs as both are on 2 foot centers. With 8 inches of the stud attached in the center of the pair of plywood trusses the hinge point is now eliminated. The little blue block under the truss is a 1x4 with the top edge at
7'6" . I will later use this as a nailer for a trough style indirect lighting valance. (Think rain gutter).
The cupalo will be framed exactly the same by simply using taller studs for those 4 trusses making a 6 foot long cupalo 24 to 36 inches tall.
I am in hopes this unusual framing method will add a great deal of strength but remain an extremely lightweight roof framing system. It will be covered with with 1/2 plywood and a padded rubber roof.
Hi Bob,
Looks like you have a great solution for your concern of any
lack of rigidity in the structure. You're in essence making small
individual 'bents' [like the big ones they make in large timber
framing, that are installed to make 8ft wide "bays", here you'll
be doing it on 24in "bays"] that in essence become one unit
with the gluing and screwing of the sidewall studs at [and as]
the ends of the foam filled small box beams you're making for
the roof trusses/cross-members. I'm guessing you'll be using
a plywood for the exterior wall surface that'll give you all the
shear strength for that as well as tie the sidewalls to the floor
structure.
Also - if you do the retrofitting of a sliding glass door [as
Catherine suggested] frame with the wooden 'baggage' door,
instead of only doing one door thickness, why not do a double
thickness [for more insulation] that will just use both of the tracks
simultaneously as a single track for the 'baggage door'? - don't
know what you were finally thinking on that...
Norm/mezmo
Norm:
The baggage door will slide between "Two walls". I will have an outer 2x2 wall for the exterior and to transfer the shear and an internal wall of 2x2 as well. The space inside will be wide enough for the door assembly and 2 layers of thin plywood to guide the door into the pocket. Both walls will be filled with 2 ply of 3/4 blue foam. Gasketing to keep the weather out is still a question but I am confident I can come up with a combination that works. This door while operational will be mostly for show. The only reason to incorporate it was for ease of construction and installing larger pieces of furniture. ( The only large furniture I can think of is the mattress) but larger sheetgoods would be much easier to wrestle inside. I am chomping at the bit but will have to wait for the April showers to move out. Then there will be some serious strides made in demolition and then the rebuild. Right now the crumpeled shell is offering some weather protection to the floor and some inside features I hope to salvage so removing the sagging roof now is an invitation to water damage that I am hoping to avoid.
image.php
As I have often said I would rather be lucky than good.
Had a customer call Friday late and wanted us to design a small house in a shipping container for a possible customer with thousands of these units.
The interior dimensions were 7'5" wide by 20' long. ( sound familiar? )
I took about 8 minutes to drag off my caboose floor plan drawings and some of the space saving wall mounted furnishings and they presented them as very rough preliminary design ideas. Their customer went crazy for them. They expressed an interest in a possible first order of 200 units for us to fir out internally and possibly incorporate some of the built in ideas.
It's still "pie in the sky" at the moment but it was sooooo neat to have the answer they were looking for right under my thumb.
If that would happen to anyone, it would happen to you Bob. What a great thing, hopefully it all goes well and he buys more that 200.
Congrats on being so informative to the customer 8)
Maybe now you can get better visuals for what your trying to achieve 8) and learn from someone else mistakes :twisted: I know for my tiny house design one of the things that I have been trying to do is where ever there is a dividing wall instead of just a wall I've been adding in a closet so that way you could get some extra storage spaces :D
I have designed to 7'6" ceilings for a reason also. A stack of 12" wall cabinets consisting of 3 - 30" cabinets will become the dividing / storage/ walls. The unfinished backs of the cabinets will become paneled or mirrored or, in the kitchen area lined with filon for easy wipe down. Perhaps in other areas a bulletin or a chalkboard could be added. No surface is to be wasted.
Behind my dumpster door you can (kinda) see the pantry in my current kitchen it is made exactly the same.
image.php
Well the Craig's list gods were good to me....
16 vinyl thermopane window sashs of various sizes just over $3.00 each
The first money I have spent on the caboose build so far but a great start.
Each sash will become a small pocket window. I was originally hoping to rip the wall studs from 2x6's to 2 3/4 - (actual) width studs but with the pocket windows and the need for insulation it will require a larger wall cavity. I think I can cantilever the 2x6 bottom plate off of the 7'6" wide floor by a couple of inches without any structural degradation. With such a narrow home every inch is precious. I Don't want to feel like I am living in a hallway. :o
I found myself, like many others, wondering how to find a place to park the tiny caboose when I have it completed. Then it came to me.... I tenativly called my new business "On site SEEcurity" Remote wood lots , construction sites , and other sensitive projects my have a need for a presence on site to help deter theft, grafitti and outright destruction. If I were to advertise and approach large project managers with the simple fact I will live for a contracted period of time on site to simply act as eyes and ears and a visual presence to deter these threats it may be of value to the project and might even provide the perks of free utilities. Costs would be by contract with the longer the contract and the better the utility benefits the smaller the cost would be on a sliding scale. I now have a small income instead of an outgo of cash for a spot of ground. What do you think?
Bob when I was looking into my tiny house one of the things I thought of was managing a rec site you get a government cheque if there is power there they let you hook up to it usually for free there might be a small list of things to do but its never more then 40 hours a week and the nice thing is they supply everything..or there were the ones where you get a percentage of what is made and you maintain the area that way but those are more for the government sites..hope that gives you some food for thought
I read a similar [good] thought on some Site like 'RV Stealth Living' a while back.
To me, the trick would be to 'step outside' yourself [or myself] and do those lil things that infer credibility. A nice looking TV, and a crisp appearance to how Accessories are stowed, etc.... An old concept is that ~70% of how we're understood when communicating is non-verbal. A nice Notebook/Portfolio of Jobs you've done would help sell yourself, and would reduce how much 'imagination' your potential Customer would have to use before signing you up.
Other than that, the trick part to me would be to 'deliver'. No excuses. That is, there better not be a break in or theft, say, of Copper Wire on my watch while I'm providing my paid-for Services. Perhaps I would have to string up some Motion Sensing Lights, on the Contractor's Electrical, and so on. There's some mega-Houses built around us in CO, and those provide opportunity. Me, I like clean Industrial Sites, like High Tech Campuses, as places to hang out. They suffer serious losses when they get hit, because there's so much Material or HVAC Equipment around, post-Delivery of that Equipment.
As told here before, an Electrical Contractor pal got his CT cleaned out twice on the Job Site of all his Tools. The Door Lock Cutting Tool of choice was a Battery-operated Diamond Blade-type Saw. To my thinking, you would have to think through your runs to the Store, or Tank dumps, to ensure you're around most of the time. As your Business grew and money permitted, a Video Logging Recorder might be appropriate to help ID Bad Guys and infer your credibility. Those multi-Camera Video Systems seem a reasonable price at, say, Costco...
The cost of bonding and insuring a small business such as this would be minimal and carries a great deal of credibility to a potential client. Motion sensitive camera equipment would be a plus as well. I do not intend to be a 24-7 security service but a on site presence with limited liability for an incident. If they need or expect a security service they need to hire one. The criminal element tend to use the off hours as their window of opportunity so the evening and early morning hours would be most likely,and these are the times when I would most probably be on site.
Do you think I could write off the dog food and care as a business cost if she was listed as assistant security personell or an alarm system :whistle:
image.php
image.php
Hello Bob I am a licensed security guard through the Justice Institute and have a K9 training course I have been able to write off all dog related expenses including the transportation vehicle that is used for it you can write off a percentage of a lot of things just have to get creative in how you do it. I personally wouldn't want to have to do the business side of a company that uses dogs as it can be a major hassle but to be an on site Representative might be a better type of position that your looking for so more of a secretary but on a site I'd also see what types of perks would be available for you. I know there are some construction companies that if you live on site pay for all your trailer hook ups propane water-sewer and electricity...only drawback you live on site so no guests allowed that don't work there..but that can be a blessing as well as a curse ate times I like the idea of maintaining a campground only busy during the weekends and you get to make some money while you sit back and relax if your a social person then it would be an easy job for you..can't wait to see what you decide on doing sure it will be interesting what ever route you take :twisted:
So maybe my idea is not so crazy after all :D
I simply tossed it out to see if I was a bit crazy but it appears there is a need and it just might be a nitch to fill. I know of no such service short of full 24-7 security staffing which would be far more expensive.
I am starting to have a good feeling about my tiny house adventure :twisted:
image.php
Well Craig's list was good to me.... 2 nice wood doors $17.00
Got so excited I went home and stripped down my mini barn delivery trailer ( NO this is not the Edmond Fitzgerald) I am going to use the 8x20 trailer I already had to test build the frame work for Eddie. It will be later used as a shop and support area for the mechanicals such as the larger battery banks and waste and fresh water storage as well as my tool storage and a piddle around shop.
I have a question.......
As I am reluctant to start a caboose collection on sight should it be a box car or a dining car?
image.php
existing deck on the delivery trailer was a "BIT" weathered. I pulled most off by hand with the help of a 2x6 to pry a bit here and there .
image.php
The AC unit was a $40.00 purcase form one of my co workers it is the exact same unit as is currently on Eddie and I am hoping that between the 2 I can repair and rebuild into one unit for the caboose.
image.php
If you look in the lower left you will see the outboard 4x4 is lower the "wings" have been bent down. A little repair and reinforcement will be in order but I have a good plan. More details later....
image.php
These shorter 4x4 will be replaced with 3 foot longer units to cantaliver out the rear observation deck. I will move these to the front to make a small observation dech there as well but it may have to be abbreviated as the tongue length will be a problem if extended to far.
Pardon me while I babble on......
Friday was a milestone day, I stopped to ask about a little 14-16 foot Layton camper I pass each day to and from work. Turns out the fella recognized me from the across Indiana TV segment we recorded 2 years ago about tiny trailers. (It is repeated here and there and apparently it aired again just a few weeks ago).
Anyway I asked if there was a little 3 burner stove/oven in the little trailer I could buy. He led me out to the trailer and we took a tour. There it was, a harvest gold little 3 burner stove and oven with matching vent hood :worship:
image.php
While we talked he said he was gonna scrap it out and anything else I wanted was up for grabs. He pointed out the small gas fired water heater and the gas furnace and the sink and the bathroom fixtures and the best part, it's all free for the taking. Did I mention I like free. :chicken:
I am gonna pull them next weekend and yes I will have pictures then.
Nice score there are some good finds if you know what to look for cant wait to see pictures
