Building a Larger Camper on a Pop-Up Trailer Frame
ddc612
Senior Member
Joined
Feb 2, 2011
Posts
264
I started a second build back in spring. First was a New Cub design with my own twist. We've been using it for about 10 years I think! We've enjoyed it, and decided something a little bigger would be nice. I've got the floor, walls, and roof about half done. Got the interior cabinets half completed. Faces to go for the most part. Wired the cabin the last few days. Thats been a challenge! I started with an old pop-up camper frame, and it's proving to be a real pain so far. The floor height is too high as it sits now. I may have to move the axel back for the 60/40 rule. I did replace the axel with a longer straight axel to get the wheels outboard of the body. I'm thinking I should have went with a dropped axel. For now I'm concentrating on building the cabin out. Then if the frame needs changing, I'll get it from there. Here's a couple pictures from a couple months ago. SideView1.jpg
Looks like a good start, if I ever do another build it'll probably be a cargo trailer conversion. Something I canbstand up in and walk around. There are of course things I'd do differently with the camper I built from scratch and that has popped in my head but I quickly push it out. As it is I still have major updates I am planning for the existing one. Started in 2020 and have been using it for years now, holding up very well, I'd be hard pressed to justify another and get rid of it. Heart and soul went in to it (and blood and sweat).
Post more pics, we are interested in the nitty gritty details.
I notice you are using underlayment plywood. Underlayment is smooth and stable but not necessarily very waterproof. It may be much less waterproof than you think. I built my first with underlayment plywood on the doors because it was smooth. But within a few years it had delaminated under PMF.
Throw a scrap in a bucket of water for a few days and see what happens. If it delaminates, you may want to replace it with an exterior plywood or takes steps to waterproof it.
If you haven't covered it yet I'd paint the whole thing with "the mix" (thinned oil based poly) to improve its water resistance.
Pmullen503, I cut off a scrap and threw in water for 10 days. Its held up well! I'll admit I'm cheap in some ways! I buy from Home Depot and Menards. Mainly cuz Menards is a mile away from home, and HD is near work along with another Menards. So I use what I can get after researching what I can. I plan on giving the edges at a minimum of a couple coats of Sparvar to seal them, then spread the rest out from that. The last build was completely covered by the time I was done.
Philpom, I'm planning on more pictures soon! I'm stuffed in a 3 stall garage! Two teardrops and the wife's car! It's a pia to take clean, clear pics! The 13yo pickup is kept outdoors by no choice now! I too seem to have endless changes to the original build and definitely will be hard to sell it come spring!
