sometimes if you have no skills or experience with the project you are trying to do it is better to start with a smaller project to learn skills and build experience.
I wanted a to build a tear for a few years before I tried, before that I had wanted to build a wooden boat since about high school. I assisted with boat building as part of a group, however the leader of the group was a professional boat builder/carpenter and I knew I couldn't build to his standard on my first try. Finally after 15 years or so I decieded to build a small simple plywood boat, I took me two years, one to mostly build it, and another to actually finish it. I took it to a local pond where I found no one there as I expected.
Amazingly it floated and was easy to paddle. I learned I could build a functional boat and no problem should be a "burn it and start over" problem. For me, sleeping on a problem tended to allow my mnd to work the problem over, many times the answer came in the shower or driving to work the next morning. (most boat builders (and tear builders?) have a "moaning chair" , a place to sit with a drink and survey the latest road block while studying the plans reading what others have to say)
After my third boat I built my tear with the same materials and construction as the boats. Now I've built 7 boats
, have two more under construction, and can't wait to build a foamie.
a big project is a bunch of small steps, making a woodie makes each of those steps harder or take longer as most of the wood work will show. Many tear builders are also boat builders, a small boat could be the best start to a tear.
And now ya thinks ya can build a teardrop?
