cast iron aebelskiver pan for the teardrop
Cubbie0708
Member
Joined
Mar 8, 2010
Posts
18
After several years of looking for a Griswold or other vintage cast iron aebelskiver pan at the thrift store, I finally broke down and bought a Lodge from KaTom: https://www.katom.com/261-P7A3.html
It took me a while to get the confidence to fire 'er up and my first few batches were kind of a disaster, but I persevered and now it's my husband's favorite breakfast. Probably the pat of butter in each little well has something to do with that.... Anyway, I found a smaller pan (I think it's a "Norpro") at Goodwill that I thought would be the perfect size for the teardrop - and it is!
Here are the two pans, side-by-side for comparison:
image.php
image.php
What I like: It's more compact than the Lodge and it weighs less, both pluses for the teardrop. And it's cast iron which I like more than aluminum.
What I don't like: I'm sure it's made in China...'nuff said. The wells on the thrift store pan are a little shallower than the Lodge so I end up having to make a "bonus" 1/2 batch. The heat isn't as well-distributed through the thrift store pan (hotter on the outside, cooler around the handle) as the Lodge. If you look at the bottom of the two pans, the well closest to the handle on the thrift store pan is an extension of the handle - probably why it doesn't want to heat up properly - the Lodge is a better design. The thrift store pan doesn't sit very well on my (Camp-Inn) stove - the ring around the outside wells on the Lodge helps to stabilize the pan and probably improves heat distribution, too. I'm willing to bet a Camp Chef (http://www.campchef.com/cast-iron-gridd ... s-pan.html), with it's (Griswold-style?) solid base, works even better. I just happened to have a steel heat diffuser (https://www.nordicware.com/store/produc ... tion-plate) with me - it definitely helped to balance the pan and I think it improved the heat distribution issues somewhat. I made sure to fill the well closest to the handle first and then flip it last.
Anyway, I got a lot of practice using my little pan on our last trip because every time I tried to make regular pancakes, it was a gooey mess - it was actually less frustrating for me to make the pancake balls....weird, right?
image.php
Tim puts (more) butter, powdered sugar, & maple syrup on his. I like mine plain. I'm still working on making them with a dollop of fruit inside - so far, it always ends up on the bottom of the pan and turns into a sticky, burned mess to clean up.
image.php
I'm still on the look-out for a Griswold pan - I figure, sooner or later, some grandma's weird-o pan will end up at the local thrift store...maybe...more likely on Goodwill.com....I really need to go to more garage sales!
Here's Rachael Ray (exuberantly) making aebelskivers on her TV show: http://www.rachaelrayshow.com/recipe/15 ... _Pancakes/
Well, Well, now we know you have another culinary skill, Adrianne. First fresh crepes, now aebelskiver donuts. (I don't really know what you call what an Aebleskiver makes). Can't wait to try those. I will check my cast iron stock and see if I have a duplicate pan for you. There was a seminar at a gathering a few years ago that used chocolate chips in some and others with apple filling. Dusted with powdered sugar. YUMM YUMM
I love my Aebelskiver pans! I started with a Nordicware nonstick but have since acquired a vintage cast iron from an estate sale. Am looking for one more though, cast iron with the sidewall to trap more heat beneath the pan as they cook more evenly than the cast iron with exposed sides. If you're interested in some fun recipes, fancy sweet and also some nice savory versions to go with dinner, I'd recommend this book: http://www.amazon.com/Ebelskivers-Danish-Style-Filled-Pancakes-Savory/dp/1616280670
Some of the recipes aren't correct but if you start with the classic or vanilla batter you'll be able to spot adjustments made on different flavors where the liquid to flour ratios aren't quite right and make corrections as needed (i.e. the gingerbread has too much liquid listed)
I do make the fruit filled ones all of the time. Only tip I can offer is to put a TBS of batter in each well and maybe let them set up for a few seconds longer than you currently do before adding the fruit and the rest of the batter. I make sure the pan is preheated before I start so maybe that's why I haven't had a problem with the filling sinking to the bottom? Or maybe add more flour to thicken your batter just a bit? :thinking:
New posts
