bigbadbarty
New Member
- Joined
- Jun 18, 2019
- Posts
- 9
I also added a 12 volt charging station to the passenger side of the headboard. The factory location of the USB ports couldn't be worse. If you lift the bed for storage you hit the usb cables in the charger, plus at night your sheets or feet end up hitting the cables. It was only a matter of time before either the port or a cable end was going to break. Beside that, who wants to charge their phone at the foot of their bed? So, I added a charging station that has a dual USB/volt meter at the bottom, a 12 volt CLA port (I put a dual usb plug in it) in the middle and an on/off switch up top. I also added a couple of mesh pockets above the windows. The cable run was a little wonky because I wanted to drill as few holes as possible. I'm waiting on zip tie anchors to finished holding the wiring in place, you can see the run in the speaker pictures. The entire run goes through nylon finger cuff loom. I ran from the headboard down the the bed platform, into the under bed storage, then into the passenger side cabinet where I tapped into the existing 12 volt power behind the factory 12 volt power station. Now we have charging for 4 USB devices instead of 2 and a built in volt meter.
