Coachmen Clipper Express 9.0TD V-PKG
dogcatcher":hhkuiq39 said:
Thank you very much for all the detailed info about your improvements. I am super impressed and have saved this link for future reference.
Thanks dogcatcher. My wife convinced me that we needed this trailer and she was absolutely right. It's been a fun trailer to camp with together and I think it's made as many friends along the way as we have! I still get out on my own with the trailer in my signature below. It's the one I go fishing with. That's a recent hobby and I love it but I'm so bad at it that I can't wait to get home and get back to work in my garage. :LOL:
Hello all,
Currently towing a 2020 Coachmen Clipper Express (w/ V-Pkg) with my 2015 Wrangler JK. Have thoroughly enjoyed camping through the relative flatlands of Western Michigan (where I live) this summer.
However, I'm planning a trip to Colorado and was wondering if anyone else had taken their Clipper into the mountains with a 2 door Wrangler? Trying to confirm my towing set up will perform in the higher elevations, etc...
Thanks in advance :beer:
Hello Druryjon,
Nice looking setup. Here in the Southeast I don't make it to many mountains. There are some mountain people here that can help.
We have enjoyed our Viking C-Pkg as well, good luck!
Howdy Folks,
Starting my Clipper 9.0 modification program. It's a shame that this thing isn't spec'ed out a bit better. Build quality is also lower than I expected.
The AC fridge is out and is the Air Con. ( I can't believe AC was just left to bounce around in the opening). I have Dometic 12V DC fridge to install and 220 Watts of solar. Next year I'll put in a lithium battery under the bed. I'd like to install the new electrical under the bed. I have two flexible solar panels that are going to be installed on the roof. They are 4 LBS each so I don't anticipate any issues with the weight. I need to being the power in to the unit and am thinking the side near the top where the roof hinge is. There is a stud in the wall beside the window and I'm thinking I can put a hole in the first layer of the wall sandwich and fish the cables down the wall.
Does anyone know if the walls are hollow? I could look at the solar on the side port but I don't think the wire is sized for 220W.
I'll post some pictures tomorrow.
Derek in Canmore Alberta
dergrah":2df1olw8 said:
Howdy Folks,
"Starting my Clipper 9.0 modification program. It's a shame that this thing isn't spec'ed out a bit better. Build quality is also lower than I expected."
"Does anyone know if the walls are hollow? I could look at the solar on the side port but I don't think the wire is sized for 220W."
Nice looking "Catalina". I've seen that name before but still don't know why they use "Clipper", "Viking" and "Catalina". :shrug:
The build quality and some of the materials could definitely be better. The cabinets are terrible. I didn't have problems with a loose AC though. Parts of it were glued in and it was actually hard to remove. We bought ours because the concept suited us. You'll enjoy modifying it and there's a lot that can be done with them. I figured I'd use ours and possibly make a more sturdy version of it some day. If I ever clear up all of my other projects that might happen ... one day.
The walls are definitely hollow. I've tapped on it as much as I can and I don't think there's one place where the walls are skinned over plywood. The possible exception might be the side walls over the windows but only at the top. I mounted the roof rack I made at this point and the lag screws I used bit really well. Most of the area over the windows is hollow though; I'm about to install some vents there and will provide some pics. I've drilled several holes through one skin or both and have fished wiring through various areas. There's lots of "hollow opportunities".
Hi all,
Posted earlier about towing with my Jeep thru Colorado. All went well, already looking forward to getting back to the mountains. 8)
Jon
I have he 2020 Viking 9.0 V Pkg. Wondering f anyone can help me. My battery isn't holding a charge after being plugged in. Nothing running inside. The only thing is the radio showing the time. Also I'm getting water pooling just inside the door about 6 inches in. Cannot find any wet areas around the fabric or above where the roof meets the fabric. Thoughts.
Mike 1953":2jrph65b said:
How did you remove the fridge?
I can't remember the details but I started by removing the vent panel from the exterior wall so I could see the back of the fridge. I later converted the panel into a pass through door by adding some hinges and a lock to it. I think screws (2 to 4) came through the floor from the underside of the trailer and into the bottom metal frame of the fridge. There might have been a few other screws but the whole job didn't take long and and the fridge pulled out pretty easily.
There's a lot going on in this area. I removed the panel between the fridge and the 30 amp electrical cord (and later built a more sturdy one) and shortened the cord. I installed a 12V water pump in this area. Removing the fridge alone frees up a lot of space and if you don't need it or want to put another one in like BURNSIDE468 did (a 12V) it's well worth the effort.
I'm not sure if I can help with your electrical problem. It sounds like your battery is charging but not holding the charge. It's likely there's a drain some where (although you say nothing is "on") or possible that the battery is faulty. The one that came with mine wasn't the best quality.
I'm looking at installing a solar panel in the luggage roof rack. If I connect it to the exterior SAE plug there is no simple way to keep the wires steady while traveling. Don't really want to start drilling holes to secure the wires.
I found that I had left the water pump in the on position. The red switch isn't working. There is water in the tank. Looks like it was drawing some current, how I don't know. The battery is now holding a charge of 12.26V.
Thank you everyone for your input! It has been extremely educational. I have run into an issue that some may have run into themselves.
One morning on our last trip, it rained quite heavily. My wife and I figured it was no big deal and we’d just hang out in our Clipper until the rain slowed down. Suddenly, we noticed there was a lot of water on the counter on the fridge side. All of the windows were closed so that wasn’t it. I noticed there was a drip coming from the metal trim on the top of the wall. I followed the water up to the hinge and that’s when I noticed the small gap allowing the water to drip in. Pushing the fabric wall up to close the gap. When I checked from the outside, I noticed the rubber “gutter” piece was missing on that side. This seems like an easy fix but I want to be sure I get the right materials. What kind of rubber and adhesive is recommended?
We gave this a test run in the yard. It snowed that night, but we stayed toasty warm. I am a REALLY big guy and I seem to take up a LOT of space and seemed to always be where it was she was trying to get to. We made it through the night without having to file for divorce, but I'm not impressed with that mattress.
I am seeing some of the Mods you have all made and I am impressed as well as a little jealous of your skills. I'm a little apprehensive about even touching the interior walls too hard for fear that they will give way since they feel to be made out of cheap cardboard, I wonder how this thing is framed? I'm willing to bet it's not 12" or 16" on center 2x4's>
If anyone has a wiring diagram or schematic, I'd love to see it.
I saw reference to a built in charging station, but didn't see one in my 2020 unit (I don't have the V option)
I am really interested in the charging station one of you (Big Bad Barty?) installed, I would love to know the source for it. I looked around but didn't see that one.
Bigdumbhick - The interior walls are what a lot of trailers are made of these days ... light weight wood, fairly nice to look at but not great quality. If you look under your bed at back side of the wall that separates your interior from the storage area you can see the wood that is used. It's pretty basic stuff that they just skin with what probably amounts to wall paper.
As far as I can tell by knocking on the exterior and having removed a few things the framing is located where it needs to be and that's it (around windows, doors, basic structure of the corners, lid, etc.). I have not seen a wiring diagram but have made a few sketches a long the way of what I have found and modified. The wiring is a mess underneath but that seems to be an industry standard. I'm relocating things and putting the wiring in split loom while I go.
In ours there's a charging station on the end wall of the right side cabinet. It's between the bed and the cabinet which is a terrible location. I made some changes in the area of the radio above where the AC was. I included a charging station and can reach in to the trailer through the back door without having to get into the trailer to use it. It's also handy to check the voltage.
picture.php
I didn't do much work it during 2020 other than to add a porta-potty tent set up. We did get to use it several times though despite the pandemic. :thumbsup:
picture.php
image.php
Glad to find others that own this trailer. We bought ours last year and have only used it twice so far. We're going to a Jeep-only event called Jeepin' with (Sheriff) Judd in Bartow, FL this coming weekend and look forward to using it again. As a matter of fact, last year's Jeepin With Judd event at 32 degrees with 30mph winds was why we bought this trailer (after spending the weekend tent camping and loosing equipment due to weather)!
I've made a few minor additions, and am looking to do a few more. If anyone has obtained (or made) a wiring diagram it would be very helpful if you could share. ;)
PCO6":35m358a0 said:
And the spare wheel under the tongue …
picture.php
What spare tire setup did you use to mount the spare tire under the tongue? Thx.
BURNSIDE468":nvdgjc2m said:
image.php
The rod we added to allow hanging of coats, etc.
I've done something similar, but used 2" PVC pipe "T"s.... I thought I read somewhere someone used a "T" clip purchased directly from Coleman for this purpose. Anyone know where that part could be bought? I'm assuming online somewhere....
Does anyone know of a good 12V small fridge that could be dropped in the same place of the small 110V one that came with the trailer? Ideally, I'd like one of those that use either 12V or propane. We had a larger one in a 27' RV we had a few years back, but don't know if they make them this small.
New posts
