GTS225-TNT
Senior Member
- Joined
- Aug 29, 2018
- Posts
- 404
As a bit of a sidebar to this subject, I've wondered a few times how something like this might turn out in the weight department.
https://www.equipmentfacts.com/listings ... 1586475144
This one happens to be 1000 gallons, but I've seen a 1600 up close, and it seems to me that it would lend itself quite well to a somewhat roomy camper shell. One would surely not need the running gear or pump systems, as it would never be carrying the weight of the fluid again.
Pros; Ready-made top opening for a vent fan.
Weatherproof.
(Probably) paintable.
Almost critter-proof. Even bears would have a hard time getting in.
The design of the understructure lends itself well to an internal floor install.
Cons; One would have to learn plastics welding in order to install a door.
No insulating value to the material.
One would almost have to paint it to keep from being disturbed at night by vehicle lighting.
Rounded walls won't help for internal finishing.
Material probably can't be glued to. (I suspect HDPE)
Buying one new would be prohibitively expensive, but if a guy could pick up a leaker on the cheap.......
Still.....so much is already done for a builder.
Just my thoughts.....Roger
Weatherproof.
