An RVer shared their plan to convert a 4x8 welded tube trailer with a 2,000 lb axle into a 5x8 deck over platform with the wheels positioned under the deck, seeking photos and advice from others who have completed similar builds. Another member responded with detailed photos and a description of their own successful conversion, using a Harbor Freight 4x8 trailer as the base. Key construction details included running wiring on the floor, using foam board insulation and puzzle mats to create a...
More...
An RVer shared their plan to convert a 4x8 welded tube trailer with a 2,000 lb axle into a 5x8 deck over platform with the wheels positioned under the deck, seeking photos and advice from others who have completed similar builds. Another member responded with detailed photos and a description of their own successful conversion, using a Harbor Freight 4x8 trailer as the base. Key construction details included running wiring on the floor, using foam board insulation and puzzle mats to create a flush floor, and coating the wheel wells in tar for protection. The build has held up well over thousands of miles and four years of use, with a dry weight of 900 lbs.
Further discussion clarified construction specifics: the floor consists of a single layer of 13/16" BCX pine plywood, supported by 2x3s in contact with the steel frame. Two sheets of plywood were cut to achieve the 5' width, and foam board plus puzzle mat were added for comfort. The original poster expressed appreciation for the guidance and confirmed plans to start their own build soon, noting the enjoyment of building small trailers compared to cargo trailer conversions.
