Hello everyone,
Looking for some help with my daughter’s trailer that I’m helping with. This is my first time installing a dc system in a camper.
The objective is to have a dc system that when connected to her vehicle will charge the trailer’s battery, but will work independently when camping. It will not cross connect to an shore power system, even though the trailer came with an isolated shore power system already installed and due to cost she did not want to combine them at this point. Maybe in the future.
What I need help with is connecting everything in my list in the battery compartment. I have a 7 pin harness to a junction box on the tongue that I have run a power and ground line to the battery compartment. The components (already purchased) I have are:
100ah LifePo battery
100ah battery terminal fuse block
Shut off switch
Smart shunt
Dc-dc battery charger
DC 12 circuit fuse panel
At this point I have already run all the interior lights and charging ports lines with a dedicated ground and power from each fixture back to the dc fuse panel in battery compartment. I ran a good ground (white) from trailer frame to junction box and then a power (black) and ground (white) into battery compartment.
My question is how to hook up each component in the system between junction box power and ground that I fed into battery compartment and fuse panel and in what order/series.
I am not an electrician and my terminology will be wrong at times for sure. Basically I know enough to be dangerous! I don’t want to damage any components by installing them incorrectly. If your instructions could be tailored to a novice without all the electrical terms, I would be grateful. Thanks in advance,, even if you just read my post and not respond. Hopefully someone else can learn from this thread too.
Shut off switch
Smart shunt
