ChainedTraveler
Member
I'm considering putting together a 24v power station with a 2k watt inverter and 2x100 ah batteries. It would be overkill for my teardrop but it would serve a dual purpose of working with my home generator to power the house during power loss. It would be easy to connect because the tear drop is in the garage.
Recharging would be done with a 20a or 30a or 35a 110 charger. Camp generator is a small tailgate generator. Home generator is a 5500.
I want to be able to keep the fridge cold and run a small window unit...both as needed so I could get a couple hours run time on battery before having to start the generator.
I would also have the option of adding a couple more batteries for home use to up the system to 200 ah total.
My main concerns are space for the inverter and 2 batteries in the trailer. How well will the smaller generator work with a 35 or 30 amp charger. And whether or not 2400 watt capacity would be worth the effort.
