DIY Squaredrop Pod Build: Pop-Up Roof, Insulation, and Weatherproofing Advice
Thread Summary
Summarized on:
Original Member Title: Hi! DIY Squaredrop builder here!
A new member shares their detailed plans for a 4x8x4 DIY Squaredrop camper pod, featuring a removable design, insulated clamshell pop-up roof, and amenities for both winter and desert use. The build aims for versatility as a remote work office, with marine epoxy and Raptor Liner planned for exterior protection. Experienced RVers quickly weigh in, cautioning that epoxy and bed liner alone may not prevent wood checking or water damage over time, especially in extreme climates. Multiple members...
More...
Depending on where you are with your build/plans, you might be able to use a couple of ideas from my latest clamshell build, although it's a TD not an SD: "saddleboxes" to extend WOA from 48" to 62", and walls that go up with the pop-up. It also has slideout bunks-- doable, but yeah, a lot of work.
Happy Clamster do you have any pictures of your latest build? I would love to see your clamshell design.
I didn't do much by way of documenting the construction process, but here's a couple of shots that illustrate the main exterior features. First is last year's edition of the Clamster, starting its maiden voyage. Second shows the clam opened up, and the slideouts slid out; also reveals the unsatisfactory oil-canning of the original polywall skin. Third shows the new skin acquired over the winter, with the main roof raised but the auxiliary roofs and walls yet unslid and unraised.
For sliding the "pod" on and off the trailer, incorporating PVC "boards" instead of wood. When I was doing my build, I used PVC pipe as rollers, but PVC boards, (you can get them in 1/4 inch I believe) are very slick and will never rot.
