DryHeatDan
New Member
- Joined
- Jan 31, 2021
- Posts
- 5
I have a Koala Bear that is about 1,300 pounds loaded and tow it with a Honda Element which specifies 1,500 lb max towing. The 15% rule of thumb for my Bear says the tongue weight should be about 195 lbs. I tried weighing the tongue on a bathroom scale and it showed 61 lbs over at 256 lbs, or 19.7%. First question - Will using a bathroom scale give me an accurate reading at these weights? The videos I have seen online for figuring tongue weights seem to be for much heavier trailers. Second - is the overage something I need to worry about? Third - if I need to worry about it, any suggestions what to do about it? And, last - should I consider a weight distribution or equalization hitch?
Thanks.
Thanks.
