Done drawin', got an Esterel!
navigator-FRF
Senior Member
Joined
Jul 10, 2007
Posts
189
All the drawing, calculating and dreaming on how to build the trailer I want is over. Been looking for two years, finally found the production trailer I have based so many of my designs on: an Esterel!
It's an '87, and in excellent condition. Well, judging by photos and the seller's description, anyway. Haven't seen it yet. Will have to drive 800 miles (one way) next week to pick it up...
At 16.5' (overall) it's 4' longer than I would like. But for the price, and not having to build anything, I'm quite happy!
image.php
Sets up like the Aliner type trailers with more room. Seems like a nice easy setup.
Hope you enjoy
I like that when in the folded position it's low enough to have a bike and/or boat rack at a decent height for easy loading and unloading.
That is cool. Easy to set up, per the video! Is it insulated at all? That would be a real plus. Searched the net and found one for sale in Quebec and another in Penn (if I remember right).
Good find.
Gus
Navigator,
That's great! You'll be pressed to find a better folding trailer than an Esterel. I would have owned one if they were available around here!
Hope you make wonderful memories with your new camper.
Congratulations on your new trailer! She looks good in the picture. I don't envy the 1600 mile round trip to pick 'er up, though! Don't forget to post more pictures when you get it home! We'll be watching for them!
Sorry for delay on more pics, will get some better ones soon. The trip to get the trailer went well: three days of driving. On the way home the wind was HORRIBLE (closed I-40 due to dust storms), but the trailer made little difference to my Tahoe's handling. Lost the roof vent somewhere in NM, and of course it's an odd European size, can get one but will cost $95. Will probably just enlarge to standard 14" square.
Took it out for the Memorial Day weekend, Thurs-Mon. Pulled it up a mountain and camped at 9,200', with a snow bank in front of our spot. Temps from 40s-60s, but slept very warm without using heater. Yes, the trailer is insulated; the upper walls are a composite of aluminum/foam/plywood, the lower body walls using fiberglass instead of aluminum. The floor is ply/foam/ply. The roof is fiberglass/foam/fiberglass. The wndows are double-layer plastic (lexan?), like a thermal window (as was the roof vent).
image.php
The ladder is used to place the chain that the air chairs hang from. The awning poles were later adjusted to be level. There were three of us in the trailer: me, the wife, and our 13 year old daughter. A bit crowded, but not bad. Better for two...
I would reconfigure the interior, remove the mini kitchen and other items, and try to maximize the storage space. Wife not so sure about that. Maybe later...
It tows very well, and it's great to be able to see over it. The design is not the best for dirt/off road, as the tongue is mounted under the frame, hanging 6" under it. The spare is mounted under the frame, too, reducing rear clearance.
The brake system is cable operated, and works fine. It is an "over run" type; when you slow down, the hitch's inner tube moves forward as the trailer pushes forward, tightening the cable and activating the brakes. There is also a parking brake, very handy.
I am considering mounting the tongue to the front of the frame, instead of under it, but will have to look it over very closely to make sure it's strong enough that way. Would also like to change out the AL-KO torsion axle for a TorqueFlex, to get more clearance and to have electric brakes (and easier-to-obtain repair parts). Change from 13" to 15" wheels, too.
But, overall, I really like it! It is very easy to put up and down, is quieter, warmer, and darker (with curtains closed) than a tent trailer, has 6' 2" headroom open and is only 4' high (from ground) when closed. It's easy to move when unhitched, since it only weighs about 1,400 lbs.
Talked to a fellow in Indiana who had one for sale on Craigslist for $1,900, no takers; he then put it on eBay and sold if for $3,200! Person who bought it was in TX...
Esterel's were imported to the US for a couple of years, so there are some around, and they are "Americanized" with DOT regulation lighting, and 110 volt instead of 220 volt circuits.
Love it! Can't wait to see the inside pics. We only got to about 90 over the weekend here.
Spent another three nights in the Esterel on the mountain, this time it got down to 29 degrees at 6AM, into the low 60's during the day. Snow lingered in very few places, and none in camp.
Discovered the furnace works using the converter, but not on battery. Where we are camping power is supplied by a large diesel generator, which is turned off at night. A bit nippy by the time AC is restored! Suspect the problem is low voltage to the furnace (which has electronic ignition, no pilot) due to too-small wires from battery; the blower works, but no flame.
We stayed pretty warm, though, and much more comfortable than when surrounded by canvas! Despite the wind hitting 32mph, no breezes got through, and the trailer never felt unsteady.
Major issue: The rear dinette converts to a full-size bed, which is what we used; the power convertor is under it, against the rear wall In order to change from shore power to battery, you have to flip a switch on the convertor, which is really hard to reach! On your knees, with a flashlight and a pole to extend your reach... Also, the convertor does not charge the battery. Will be replacing that thing with an automatic-switching unit that has a built-in charger. (And put in larger wires from the battery.)
The first photo shows a profile of the trailer, where you can see how low the tongue is, just ahead of the door. Also note the spare tire under the rear. We're going up again next week, for eight days, and will get some "lived-in" interior shots then.
image.php
image.php
Wow and we had 96 degrees yesterday with heat index of 102! What a difference. Still love your little unit and it looks to be in good condition. I saw an original Shasta with the wings pull through the parking lot at the Kroger here yesterday. Looked like some one had just purchased it and was taking it home to clean it up. Made me drool.
Gotta love some of those little retro campers!
No new pics, but some updates...
Trailer was great for the eight-night campout, especially with just two inisde. This time the temps were into the low 70's during the day, upper 50's at night. After getting home, I started reworking things...
Took out the convertor it came with and moved a newer electronic model to the other end of the trailer, where it will be accessible. Added a circuit distribution center, a combo 120/12 breaker/fuse box I found on eBay. Also moved the power cord to be stored next to the convertor.
Moved the furnace to under the front seat, to free up the space under the bed. It's a Duo-Therm, so there was just a small hole to cut in the side for the vent.
Ordered a pair of 11.75" x 40" cargo doors off eBay and put them in on each side, under the bed. Now that space is very easy to get to to store chairs, the awning, etc. Took out the rear dinette and made a matress support to fit, using plywood and some square aluminum tubing. Even got permission to take out the "kitchen" cabinet (sink/cooktop/fridge). Not sure what I'm going to put in its place, but it will be just storage, as cooking is done outdoors.
The suspension is just bolted on, so I'll put a 2" square tube between it and the frame to get a bit more clearance, and not mess with the tongue. In two weeks we take it up a narrow, twisty dirt road for a three-day outing, we'll see how it does on that road...
Need to put in a larger water tank and an instantaneous water heater, so we can be civilized with hot showers.
