door thickness versus wall thickness
shooting4625
New Member
Joined
Oct 24, 2025
Posts
4
Location
84737
Hi all
I am seeing premade doors that recommend wall thickness 0.7" - 0.8" if you end up producing a 1" - 1.25" thick wall I presume you can still use these doors just a longer screw required for the inside trim to reach the main part of the door.
Thanks
Colin
That may be true. It might depend on the inside trim, and how deep it will penetrate through the wall. There may be a sliver of raw wood/foam exposed between the inner and outer "halves" of the door assembly.
Seems like the door mfgr. is fabricating a door that is quite minimal......like for a 3/4" wall, with no insulation.
Roger
Roger
Agree, might need to create a filler piece between the inner and outer frame.
New posts
