This was probably covered in the pinned tongue strength post above, but the links don't work for me.
It seems a lot of guys who build their own frames just butt weld the drawbar a-frame to the front face of the front cross member of their rectangular main chassis.
If they put a centre longitudinal piece in, this often gets welded to the front of the chassis, too.
This isn't the strongest of methods, in my view. The A-frame will always be exerting some twisting force on the front cross member and trying to tear the butt welds.
My a-frame is somewhat like this and it bugs me a bit.
Would be somewhat better if a brace/gusset was place underneath to reinforce it.
But I think the thing is best built with the rectangular main frame, a-frame out the front and that centre longitudinal drawbar passing under the lot.
Or just do it a la NT and HF trailers, but welded from decent size material rather than bolted together aluminium foil.
If you look at Tony Latham's plan, the whole lot passes under the main frame. Much better distribution of the forces at play, I think.
