First Foamie Bugout Design
Thread Summary
Summarized on:
A member shared their process for constructing a 5x8 foamie camper on a Harbor Freight trailer, emphasizing that the extra foot of width over the standard 4x8 makes it more comfortable for two people. They used 2-inch pink foam from Menards, cautioning against the type with scribe cut lines, and joined the panels using a hot knife to create finger joints (initially referred to as dovetails) with expanding foam as adhesive. The exterior was finished with "poor man's fiberglass" and multiple...
More...
fr3dcat
New Member
Joined
Aug 18, 2025
Posts
4
Location
Fairfield,OH
Start with a harbor freight trailer and build a 5‘ x 8‘ platform which was larger than the 4‘ x 8‘ trailer that extra foot makes it better for two people to sleep. I use 2 inch pink foam from Menards. There’s two types there’s a type that has a scribe cut line-don’t use that or there’s a type that has no cut lines. I used a hot knife to make a dovetail type joint and I used great stuff, expanding foam as my Adhesive. It was finished with poor man’s fiberglass in about eight coats of latex paint I got that was cheap at the Habitat for Humanity store.
Technically that's a finger joint, dove tails are slanted to lock and align the pieces. Still, a good way to help align the pieces during assembly.
That’s good to know I knew it wasn’t really a dovetail, but I didn’t know that was what you called it. I did think about doing a dovetail, but I figured I’d screw it up. The expanding foam is great for sloppy joints. It’s strong and it tightens it right up.
For us first time builders anyway
I think you could build a couple jigs and use a hot wire to get pretty accurate dovetails (or finger joints for that matter.)
The strength is in the canvas covering so the joints don't have to be perfect.
