flexiride and ground clearance
Jonnyo
Senior Member
Joined
Aug 20, 2011
Posts
162
my trailer frame aluminum 6.5 x 13 36'' tongue
1. dexter torsion vs flexiride: i know how to install a dexter with side mount. you weld the side mount to the frame and bolt the axle. simple
flexiride: how do you install those? i cant find any good documentation??? there website isnt great to education and informe. Do you need to drill the main frame and bolt the axle in it? is it a problem to drill holes in my 2X3 aluminum frame???? Anyone as good pictures of there set up? i would prefer a flexiride as i could set the trailer for road condition with lower drag and also have option to set it up for light off road...dirt road trips.....
2. what is the minimum ground clearance that i can have on my frame. i want it as low as possible so it dosnt come up much pass the subaru forester roofline. Trying to make it as good and easy to tow as possible for a ratter bigger ''tiny trailer''. what do i need to take into account with a 13 foot long trailer? would 10 inch ground clearance be enough? I define ground clearance from the side members of the frame...to the ground. The tongue goes under the frame and made of 2x3 and 3x3.... so that tongue will be 3'' lower... Is it the proper way to mesure?
any help would be appreciated.
This is the only picture I have of mine. There is a 3"x3" angle iron welded to the side rail that the axle is bolted to. The Flexride came with a flange welded to the axle with 2 holes in it. Since all the articulation is in the trailing arms the axle can be attached right up close to the frame.
I struggled with that too. Never did find good flexiride documentation. The website at Southwest Wheel makes no mention of hanger brackets.
Would not want to drill through the frame tubes which may weaken them. Thought about making a "hanger" from an L welded inside the tube frame that the flexiride bracket could be bolted to. Seems like it could work. Would need to carefully specify the hanger bracket measurement and the hub to hub measurement. For most trailer tires the resulting overhang seems to be within spec.
My axle is a Dexter #9 with the extra hanger brackets.
edit: Just saw Woodbutcher's post and photo (above). His idea is a little different than mine where I suggested welding an L inside the tube frame. His method looks easier to do because the "frame measurement" would be easier to figure and there would be less overhang. It's simple when you see a picture of a good (brilliantly simple) idea. I spent countless hours trying to figure that out and never came up with a design as simple and affordable to accomplish as his.
:thumbsup: :applause:
You may need to be careful when you join a steel axle to an aluminum frame. Maybe use some kind of spacer in between them and stainless steel bolts? :thinking:
Could we nominate Woodbutcher's idea and photo for a sticky in Chassis Secrets. It would be of great help and solve a lot of head scratching. :thinking: Mike, admins?
Thanks Mike and admins. for making this a sticky. Thanks Woodbutcher for sharing your brilliantly easy solution for a better way to mount a flexiride axle to a trailer frame, your "how to do it" explanation and good photo documentation. It will help many trailer builders.
The thought just occurred to me that Woodbutcher's idea allows the trailer axle to be moved forward or backward too to get the "best" trailer balance. Doubly brilliant. :thumbsup: :beer:
For technical data on Flexiride, go to the manufacturer's web site:
http://www.ucfamerica.com/tech.html
There may be more information than you wanted and spread across several different documents, but it's all there somewhere. You do need to be able to read a technical drawing.
as i mention, i already read almost everything about that website. Could not find any drawing of the mounting options or recommendation. That said, i have no presomption to say i m good at ready this stuff, i have no knowledge of mechanical of building stuff... That s why i m writing here to see if someone can help me and explain to me in more simple terms?!
also, maybe a simple question instead.... is there any issue with bolting a axle straight into a aluminum member of the frame??? Seems like many company are doing it to install leaf spring axle into there aluminum frame (snopro)
Here's mine, I welded the flange straight to the frame.
I have a Flexride on mine. There are two plates (one for each side of your trailer/frame) welded to the top of the box frame/axle, each with two holes about 8 inches apart (IIRC) front to back of the plate (ie. parallel to your frame side member) - you can either use those holes to bolt the plates to your frame or you can weld the two plates. Either way works and is recommended by the manufacturer.
In my case I used the holes to bolt it through the floor since I don't have a trailer frame on mine. You can (barely) see the plate on top of the axle to the right of the spare tire in this picture:
image.php
Hope this helps...
Try and look just a little closer.
Followed the link that Angib posted, double clicked "Data Sheet" and there was the technical drawing that he spoke of. http://www.ucfamerica.com/FlexirideTechnicalLiterature/Axle Data Sheet All Sizes.jpg
You can bolt thru your frame, but you should drill the hole large enough to weld in a length of aluminum tubing at each hole location to prevent the fasteners from crushing the tubing. These are coincidentally called "anti-crush sleeves".
Woodbutcher's method looks simple, but it adds height and weight. Also, it is not clear to me if it is putting a bending moment into the vertical leg of the angle. With the horizontal leg of the angle unsupported that could be the case. Easy to improve on, the horizontal leg of the angle could be gusseted back to the side rail, or extended and gusseted to the xmbr's at each end.
Depending on your tubing wall thickness, you might want to add fish plates on the vertical sides of the side rails between the xmbrs to beef up the mounting location.
Here s what i found from a trip to the trailer dealership
Sno pro aluminum trailer(utility) 2999lbs capacity
They use a 3/16 aluminum angle welded to beef up the 2x3 1/8 Alu tubing. Then, drill right in it. It s a dexter axle in this pic but should be able to do the same with the flexiride?
URL=http://s25.photobucket.com/user/ironjohn36/media/Mobile%20Uploads/image_zps83f11f13.jpg.html]
[/URL]
Can you see if there is a nut on the top side of the tube? I would not assume that the bolt is threaded right into the aluminum. If it is they surely would have used a helicoil thread insert, or perhaps hole sawed and access hole in the top to allow a nut and washer to be placed on the inside of the tube.
To expound on what I said above about crush sleeves; one technique is to drill the top side of the box tube to suit the bolt clearance, and the other side to suit the OD of the sleeve. The sleeve length would be the height of the box tube minus one wall thickness. In theory this type of crush sleeve configuration would not need to be welded because the sleeve would be trapped between the axle mounting flange and rail, but I would still weld it if it were me.
photobucket.com/user/ironjohn36/media/Mobile%20Uploads/image_zps23047c9b.jpg.html]
[/URL]
Not the greatest pic. But yes, a nut and washer on top of the tube. I could not see any other holes. I look at it in person but can't see if they did something special inside.
That said, I think I understand what you describe and that would be a safer way to process. That said, I m only building something rated for 1/3 of the weight of that commercial trailer
Doesn't matter what the trailer load is. You can crush the tube just by tightening the nuts. Then the tube can relax and the bolts are no longer tight. With the crush sleeves in they are in direct compression so the tube does not bend, therefore the bolts do not get loose.
Just do it.
KCStudly is correct. The steel tube can readily be deformed by tightening the through bolt unless there is a tube insert to prevent it. Bolts only make good fasteners when securing flat undeformable plates together, or when provided with tube inserts that effectively turn a tube into a solid. I've seen it with steel with my own eyes; I'm sure with aluminum it can happy with greater ease.
I found another picture. You can see the 3"x1/4" angle iron that has been welded to the outside of the frame rail. I drilled a few holes, allowing me to move the axle up or back if I needed to for the best balance. The axle just bolts to the angle iron. The welded tab is to bolt the body on with.
Woodbutcher, Thanks for sharing the additional photo and details.
Where did you weld the 3x3 L to the tube frame (along the top vertical leg of the L, along the ends, and where the L and bottom corner of the tube touch)?
Is it a continuous welding bead?
If you were to do this again would you change anything, or suggest changes for people who may want to copy your idea?
  • The Dexter side mount is made steel. You can't weld it to aluminum. So, both brands mount the same.
  • Which Flexiride axle are you planning on using? If it's the 2000/1400#, the difference in start angle from 42* down to 6* up is equal to about 3-1/2" in ride height. You could use the Flexiride at 24* down or the Dexter at 22-1/2* down and gain more change in ride height with less hassle by having a set of street tires & a taller set for off highway.
  • Have you drawn a profile view & determined the balance point in order to closely locate the axle? Using the approximate rule 40% from the rear would leave about a 5 foot overhang. That & with a 10" ride height, You'll have to be careful not to drag on inclines or dips in the road.
  • :thumbsup: Looking good.
[/URL]
  • Jonnyo, In addition to the angle, there appears to be about a 1/4" x 6" x by full length plate welded on the outside of the frame rails. Also, according to the Snopro website, they use different extrusions rather than 2" x 3' x 1/8" rectangular tube.
thank you Alaska Teardrop for the great feedback.
Dexter does sell a ALUMINUM side mount. To my untrained eyes, it s simple look like a piece of angle aluminum with a few holes for bolting. You simply weld that to the trailer and then bolt the axle. That is what i currently have on my first build (rance aluminum trailer)
A after market company also make a spacer of 2.5'' or 3'' to attach to the side mount and lift the trailer. So, with all the good advice and the rather complex way to mount the flexiride( complex for me, i think it s easier to weld a side mount for my level of skills) i m gonna go for a dexter aiming at a ride height of about 12'' with 14'' wheels. and if i want to do some dirt road/ off the highway trip...i have the option later on to lifting everything with the spacer kit.
  • Thanks for that information, Jonnyo. Can you supply a link, a source & maybe a picture of it installed on your Rance trailer?
  • My concern is how well your 2x3x1/8 aluminum tube rails will hold up in terms of the fatigue & stress with that mounting arrangement. Compared to the Snopro design it seems awfully weak, IMO.
