Foam thickness and strength??
tinksdad
Senior Member
Joined
May 5, 2008
Posts
966
Wasn't sure which thread to put this in, so decided to start a new one. I have been busy in sketchup and designed several possible variations of what I hope my next trailer will be.
The problem: The search isn't over yet; but the only 4x8 sheets of foam I have been able to find locally are Foamular 150 --- 1 1/2" thickness. I really would like to use 250 or 350 if possible; but that may not be an option.
The Questions: Will the loss of 1/2" thickness create a problem? Will the 150 be structurally sound enough? I'm not sure I understand the numbering system; but I would believe 250 and 350 would be stronger than 150.
I'm hoping the "Experts" will have some thoughts on this. One idea that is running through my head at this time is the possibility of using smaller foam sections with some thin wooden ribs between the sections and around the perimeter to add some extra strength. It will still all be covered with canvas/TB, so wood rot should not be a problem (I hope). If it makes a difference, all my designs are planned around 5 foot wide and 5 foot tall (a crouchie) on a 4 x 8 base trailer. Basically modified Weekenders or Grasshoppers.
Edit: OOOPS!!!! After I posted this, I see in another thread about using a 1/2" plywood grid to add strength/stability.
For those of us in the Southern Climates, 2" foam is hard to find. I was wondering about bonding two one inch pieces together - if that is possible :thinking:
Should be easy to glue two sheets together... Gorilla glue spread thin , or maybe a WB contact cement ... Nice thing is you can bend the 1" foam , then glue the other on top ... :thinking:
i would like to throw in here that none of us are "experts". we seriously can only speak on what we have found during our builds and what experiences have been had with using certain glues.
i love that we are all out there throwing ideas around and asking questions. who knows what will come up next with the answers. :thinking:
but i wanted to let everyone know i certaintly do not consider myself an expert by any means.
now as far as using 2 sheets together. i would make a guess and say yes, it could be done. i would think you would need to be careful of the gg as it expands, and it would seperate the two sheets. i would also think you could just wrap the two sheets together, pre canvas as a whole unit? perhaps?
That's why I put Experts in "quotes". :D I realize we are breaking new ground here and a lot of experimentation is happening. A lot of information has been posted and I'm still trying to wrap my head around some of the ideas and opinions. My main impetus was to try to get a discussion going on the pros and cons of the different strengths (150,250,350, etc..) of foam in different thicknesses. Like I stated in the OP, so far all I have been able to find locally is 1 1/2" 150. I don't want to waste my time and money if it might not be suitable.
I dont think anyone is going to say as we just dont now. Everyone is using what they can get local and they all differ. People are happy to find some at all and use what they can get
http://building.dow.com/na/en/products/insulation/rigidfoam.htm
This url lists the current Dow foams but they only list compression figures as this stuff in thier eyes is not for structural use unless its under compression. As GPW made clear on the first few pages of the "The big post" its the covering on each side that is the strength and the foam is simply keeping it apart.
This picture shows what its for, or for underfloor, i dont think you will ever see it used on its own, it always has at least on covering and normally two.
http://insulation.owenscorning.com/homeowners/insulation-products/foamular-150.aspx is for the Owens Corning Version with the Formular name
http://insulation.owenscorning.com/WorkArea/linkit.aspx?LinkIdentifier=id&ItemID=780 is the product data sheet
About 3/4 of the way down the second page it says
FoamulaR insulation is a non-structural material and must be installed on framings which are independently structurally adequate to meet required construction and service loading conditions
I think your question is the same as we all have, the data sheet says we have to fit it, in, on or skinned with something thats "independently structurally adequate", and its for each builder to make their own mind up if they are doing so.
I once wanted some metal tubing and asked for samples. The guy came to my office with them and went through how they could stand huge pressure, were suitable for high temperatures and could even be used with nasty chemicals, it was a fantastic presentation, but i was not to happy when i said I only wanted to make a chair leg so its horses for courses.
GPW and Eagle were breaking new ground and i have heard that their next project is making a Mars lander from tin foil, 2 baked bean cans, all stuck together with a bonding agent made from dried bread :?
Cant wait....
We live in one of the areas where this stuff isn't available at the big stores. We contacted on of the small local building supply stores and they could order it for us. That might be an option for you.
Cant wait....
:lol: :lol: Flour and water has been a reliable source of glue for generations. :lol: :lol:
I'm starting to think when they say structural, they're talking about uses in buildings , homes , etc. Where great weights and loads are expected ... for our small applications , it can indeed be "structural"... All how you read between the lines ... and how you use it !!!
my husband says i should build one from all his beer cans. think that could be done? they build houses with them don't they? held together with mud right?
guess he will have to start drinking lots of beer. :lol:
How about using cut up beer can aluminum as an outer covering , applied like dragon scales ??? 8) OK, I know that was silly .... it's still early .... more coffee... :oops: :lol:
Dad, bottom line , when in doubt make it Thicker ... Twice as thick is 8 times Stronger... The foam is the cheapest and lightest component , so feel free to make it much thicker... For gluing sheets of foam together ...one method we've used for airplanes was to thoroughly squeegee a very THIN coat of Gorilla glue on ,join the sheets , and then weight the surface .... no expansion noticeable ...Epoxy would work too.. Foam , being a homogeneous material joins easily , and I've made structures of made of many layers glued together , then shaped much as a block would ...No consideration of "grain" allows you to just add and subtract the material at will ... :thumbsup:
you know that could open up even more possibilites. glueing several layers together, you could make bed box frames, shelves, counters, just about everything could be done in foam huh? even though i am already a believer i think i am now even more of one.
i wonder about the white bead foam stuff. like the packing white foam. covered in canvas, several layers of that, could also make some inside elements. that stuff is cheaper in price. and its lighter also isn't it?
oh the possibilites. now back to dreaming about that lottery win. :lol:
Eagle , having used "bead board" for a lot of wings in the past ... it 's not as easily worked as the closed cell foam we use... the beads tending to tear away when cutting , makes sanding "difficult" also ... same problem ... But with a hot wire , you can easily cut out any shape you want ... and it seems to have better adhesion with T2, the glue soaking in between the beads... (all well tested)... comes in MANY weights .. same old story , to compensate for the less strength , just make it thicker ... I believe the foam we use (blue , Green, Pink) is about 2 lbs. / cu.ft. The bead board is usually half that ... but we've seen VERY dense bead board used for packing heavy items for shipping ... Haven't seen any of that commercially available ... yet ...
There is a large Insulation supplier in my area , I need to pay them a visit... wholesale only , but they offer many different types of foam( Styrofoam , EPS -expanded polystyrene-"bead board", and urethane foam , which must NOT be hot wired or burned :o ) and many different shapes , including large blocks ... and a good BS story always works , gotten much foam from them in the past for airplane construction ... just with an explanation ... ;)
Tinksdad
You might try ordering extruded polystyrene from Universal Hovercraft. I have not ordered from them however by email they told me their foam's density is 2lb/cubic foot.
Found out a few things:
In the Owens corning Foamular foam the number refers to its maximum compressive strength
150 = 15psi
250 = 25psi
350 = 35psi
This test is to 10% compression or failure, and has to meet the figures
Also I have found some strength tests but they just seem way out to me.
The data sheet says they use test method ASTM C203
From Google:
Title: ASTM C203 is a standard Test Method for Breaking Load and Flexural Properties of Block-Type Thermal Insulation
Description : These test methods cover the determination of the breaking load and calculated flexural strength of a rectangular cross section of a preformed block-type thermal insulation tested as a simple beam.
150 - Flexural Strength (lb/cubic inch min) = 60
250 - Flexural Strength (lb/cubic inch min) = 75
Below is the machine to do the tests but it does not say how long the foam beam being tested is, the data sheet says "Value at yield or 5%, whichever occurs first."
Now I have no idea about this test but i cant see how a 1"x1" beam could stand 60 pounds one inch along it
Anyone have any idea?
Strange machine....just proves the denser,heavier foam is stronger...and by how much according to their standard , yet not understood (by me) :oops: Just some kind of crush test eh ???
Thats why i posted it, as i thought there was very little strength in the foam and this is saying there is.
Its not a crush test its a bend test. At the bottom of the machine you will see 2 metal rods and black brackets. They take a piece of foam thats 1" x 1" thick and place it across the 2 bars like a beam, The verticle part then bends the beam and records the results.
The material fails the test if at 60psi the beam has 5% or more deflection
However as the beam is longer than 1" there must be some calculation.
60lbs is 27kgs so quite a lot and IMHO there is no way a 1" piece of foam would not fail with 60lbs on it.
I am going to contact them
Please be so good as to do so ... doesn't sound right to me either... Having used foam for many years , it is Strong ... if used right ...
I'm going to throw in another idea running through my addled brain. Sometimes I just run with first impulse and other times I tend to over think things. Just a thought on increasing the area for glue application at the joints.
I don't know the proper terms, so I added a picture to try to illustrate. If I can ultimately find 2" foam locally, the idea is to use the router and cut rabbets (?) at the joints and increase glue area by 50% {the blue in the picture}. If I end up face gluing 1" sheets together, just cut one smaller than the other to achieve the same effect {the pink in the picture}. I am thinking the bi-directional glue joint would add some additional strength to this juncture of foam.
image.php
If the 1" bends fairly easily as alluded to in another thread, I may even be able to redesign some curves into the trailer instead of all straight lines. Maybe a combination of 2" for the walls and 1" for the roof.
I finally found a company who supply the foam in the UK (Yippeeeee) and after a call to them they were so interested that i was put through to a senior technical sales person. They sell a lot to caravan companies as made up panels. These have alluminium on the outside and a finish ply on the inside.
The foam he suggested is what is commonly used under floor boards in house building which already has a perfectly cut rebate as in your picture (blue one) all the way round. Its available in 2500mm x 600mm (8' x 2')
When i asked about it only being 600mm high and would mean having more joints he was clear that a well glued joint is stronger than the plain foam and vertical joins can be staggered. They use a 2 part glue and in testing the foam always breaks way before the joint. The rebates fit together to make a perfect flat surface or a perfect right angle join. He explained that normally (under a floor) these are not glued together and a butt joint could slip where a rebate one does not.
He suggests that glueing two 1" pieces together is not a good thing and said as all glued foam joints "MUST" be clamped so the joint is under pressure until dry, on such a large joint a DIY builder could have a problem.
I said i was sure it could be done and he agreed but it would need a perfectly flat floor and perfectly flat weight so the same weight was distributed all over the join. He thinks with DIY when you lift off the weight the double foam would be wavy when viewed along its length.
I think he then realised i only wanted a few sheets so made an excuse to go as he had to quote on panels for 140 prison vans.
Two things he would not comment on was the use of PVA (TB2) and cloth covering and using GG on joints as he had no knowledge on this.
Company details:
I first contacted http://www.styrofoam-online.co.uk and they are also http://www.panelsystems.co.uk
lots of info on there
