FoamStream...
Here's the rib idea !!! The blocking between them could be used as attachment points for the horizontal stringers ...
image.php
image.php
Those wood blocks could be foam. I've seen pretty strong mini pallets made with foam between 2 sheets of ply. Strength and a bit of cushion.
Cliff , good idea , but then I wouldn't be able to use them for attachment points ... figured placing the blocks where the stringers fell out giving many many places to attach things ... :thinking:
just some simple 2"X2" X 4" blocks ... Cut a bunch on the chop saw with a stop, easy !!! ... This way I could assemble the whole inner framework Before I add the foam and canvas over it ... All stained and finished before hand , except for the areas where the wood meets (glues) the foam ... :thumbsup:
2x2x4 blocks... :thinking:
You could make your blocks out of 1/2" ply, or even chip board, and save some weight, and they would be much less prone to splitting.
That's not a bad idea ... plenty of that hanging around ... :thumbsup:
Hi GPW,
Just curious on this new rib possibility. How wide will they be? 2"? 3"?
Will that total width - 4" or 6" - intrude too much on interior width? - since
it isn't going to be all that wide [6ft wasn't it?] in the first place. It probably
would be possibly easier to fabricate as opposed to laminating 4" x 1/4"
strips of plywood into a 3/4" or 1" thickness. But how will you handle the
foam joints? - they were going to meet on one of the 4" wide x nominal 1"
thick laminated ribs in the original thought on it.
What will be the thickness of the plywood for the new style ribs if you go for that? If it is
1/4" I'd suggest using foam the same width of the wood [whatever form
of it you choose] blocking in addition to the wooden blocks to fill in and
space the plywood rib strips apart the whole length - a very small sip-style
rib, if you will. 'Just trying to think of some pros and cons or details for
both methods.
Norm/mezmo
Norm, you're spot on with this consideration ... I've been perplexed by this for more than a month now ... :?
This idea was to use something like 3/8" ply spaced about 4" apart with a depth into the cabin of about 3 " ... The alternative was to buy or bend the standard 5/8" thick ribs ... Found wagon places where I could buy the custom pre-bent ribs @ about 60USD/ rib + shipping ... I'd need at least 4 ...7 would be even better ...
They'd probably produce the desired effect , and the price really isn't that bad considering the cost of doing it other ways ... For example , using a CNC to cut ribs is very inefficient , unless we cut great numbers ... the drawing/ nesting , proofing ... all time consuming on a machine. The only way I can even consider doing this is a good friend owns one and just doesn't mind a different project now and then ... so it would be Free... The idea of Foam and blocks between really makes Good sense... :thinking: More contact between the ribs and foam shell ... more gluing surface!!! :thumbsup:
The other way is to laminate them from 1/4" ply ... requires making a form and a lot of clamps ... That seems like a good way too , producing a strong flat rib with no need for steam bending ... Like all the other ply rib ideas , the wood must be thoroughly sealed to prevent delam later ...
So you see my dilemma !!! Either do a lot of work ,or just throw money at it ... Considering the size and usefulness of the project , a small investment in pre-bent ribs doesn't really seem like a bad idea , and it would tremendously expedite the building process... the ribs being the main obstacle ... :roll:
Still obsessing over the FoamStream ... Just had an idea to make one angled instead of curved... No ribs other than some 1/4" "joiner strips" ... It would lose the Cool look of the rounded one , but would be easy , requiring no ribs and no kerfing ... and you would lose a modicum of headroom near the edges of the walls , but the top center section could be made wider .. Should be just as strong , much easier to make ... just a little alternative thinking ... Still , the rounded one would be much more pleasing to the eye ... :roll:
Here's a drawing of a half section , angled style ...
image.php
Not being restricted to exact curved sheets , it could be adjusted to most any size ... even taller in the middle , giving even more headroom without the drag inducing cross sectional area of a more square -ish' cross section ... much akin to a V nose CT , just more "slippery" in the air ... :thinking:
IMHO, all other things being equal, I'd stay with the rounded look. Much more appealing to the eye. :thumbsup: :D
Mel. yeah , I really like the rounded look better ... just exploring ideas ... although the angled would be easier to make ... and less costly ... :roll:
It is prettier and more roomy ... Should be very aerodynamic and Light .. for it's size ... should be a breeze to tow ... Will try to keep the AUW < 1k lb. less Gear and BEER .... hahahaha :lol:
Hi GPW,
Just some more thoughts on the Foamstream Construction.
I vote for the original rounded shape. Much nicer looking,
and the angular/flat sided version telegraphs "space constriction".
I'd lobby for going with the laminated 3/4in 4inch wide ribs. On
second thought about them they could be fast and less hassle
and not necessarily need a lot of clamps. [I know this is easy to
say/suggest since I'm not the one doing the work, but this is the way
I'd approach it.]
***The forum won't open up for me tonite as I'm
writing this, [08/23/11] so I'll go from memory on what you're going for.***
FIRST
I think a "space frame" [skeleton?] of the laminated ribs& 'boards' would be very
beneficial. It'd make it easier to mount interior amenities and any
electrical needs and eliminate the tediousness of locating and installing
hard points within the foam for any mounts or attachments.
I'd use a center top flat "ridge board" - a 4in wide
laminated board of three 1/4in plywood strips. Its length being,
from the rear end of the roof to where it joins the front quarter upper half-
hemispheric section in the front. In the center lamination of that, before
lamination, cut 1in deep by 4in wide cutouts centered and spaced where
you want the ribs to be, this will act as a mortise - and in fact becomes a
mortise when laminated between the top and bottom 1/4in plywood
lamination strips.
SECOND:
For the ribs: Laminate these as identical half ribs. Make at least four
additional half ribs to act as bottom plates/base and mid height
horizontal rails for the front curved lower section of the Foamie body.
[Don't forget some straight boards for a center upright between
them and as many intermediate uprights you want there.]
Make a jig for the correct arc - estimated as a 1/4 circle arc.
Use a sheet of 1/2 - 3/4in ply as a jig base with several @ 6in long 2x6 pieces
screwed to the base from underneath it to define the "radial end points"of/
from the center point from which you are drawing the arc. This is
assuming a radius of ~ 3-4ft representing 1/2 the body width.
- The exact radius depends on the final decided width, minus 2in for
1/2 the width of the 4" wide centered "flat ridge board". On the top end of
the half ribs, extend the center 1/4in plywood piece lamination
7/8in beyond the top and bottom lamination strips. This will act as a
"wide" tenon to fit into the "flat ridge board's"corresponding 4in wide
'mortises' on final assembly of the rib skeleton. [You also
could do the same on the bottom end of the rib with a longer tenon
[4 - 6in] if you wanted to use a full width tenon to attatch the bottom
of the rib to the lower wall section uprights/mid-rail with a corresponding full width
'mortise' in it, or to possibly attach the sides to the floor.] 'Need to
mention that you also need to make as many lower wall flat/straight
side wall uprights as you have curved ribs, and horizontal base and mid-rails for
between the uprights&ribs pieces.
FEWER CLAMPS:
To not need to use a bunch of clamps: First,
put 1-2 layers of Glad Press-n-Seal plastic wrap on the base, tight into the
'radial end point's' and base juncture angle and tight against
the 'radial end points" with a 2-3in overlap at their end, before putting the first layer/layers of
glued plywood strips on the jig. Have the strips rest on edge
against the jig base and their 4in width resting and bent against the "radial
end points" on the jig. Then use small brass or aluminum
brads/nails or screws to hold the 1/4in plywood strip laminations
together while the glue you've applied dries and sets the curve. These can
just remain in place once the glues dries/sets. REMEMBER: These fasteners
MUST NOT PIERCE the total thickness [or interior face ply] of the 3 ply lamination made
up by the 1/4in plywood strips - or - i.e. either use 3/8in long fasteners if you
use them for laminating the 1st two plys/layers together, and the last ply/layer
layer to the resultingtwo ply/layer piece or 5/8in long fasteners if you just fasten
all 3 layers together at once for the total 3/4in thickness of the lamination.
ALSO:
The heads of the fasteners should be flush with the top of the
ply they are applied through. Once the three 1/4in plys are glued, bent and
fastened together to make the 3/4in laminated board/rib,
then cover that resulting laminated board/rib
with 1-2 two layers of Glad Press-n-Seal plastic wrap, have @ A 2-3in overlap
on the 3/4in side of the newly laminated rib with the rest of the Press-n-Seal
smoothed against the 4in width of the newly laminated rib and then snugged
into the angle where the laminated piece rests on the jig base and earlier
laid down Press-n-Seal layer on the jig base and then the
remainder of this new Press-n-Seal layer smoothed tight onto/against the jig base.
The Press-n-Sesal will stick to the wood [and itself] and prevent you from gluing
all the boards/ribs together into one big piece, AS LONG as you DO NOT PIERCE the
plastic wrap 'layer' between each laminated board/rib that you are
making. Then, repeat the process. Just form the next board/rib on top
of the one you just completed as it will have the same curve. Just keep
aware of the working times of the glue you use and be sure to
locate and wipe up stray glue spills and such. You'd only need
3 - 5 clamps max with this method, one on each end and one
in the middle as a minimum. The small fasteners are taking
the place of multiple clamps. Use as many of the fasteners
that will just do the job for you. Since they are brass or aluminum
they can remain w/o rust problems and the heads will be external and
covered by the foam panels once they are attached and are thus out of sight
ALSO:
When you are doing assembly of the skeletin frame, if they don't fit
easily when you dry fit them, just sand the tenons a little and perhaps
slightly bevel the tenon at the sides ever so slightly, then it should
fit ok. Once the fit is to your satisfaction, you can then glue it up. You
can clamp the joints if you want, but drilling a pilot hole and using a
couple 5/8in brass screws from the top will hold the joints in position.
And I'd reinforce the outside of the joints with fiberglass tape and
glue/epoxy also - trying to tie all the pieces together into "one" space frame.
THIRD:
For the front quarterspheric shaped piece, here
are a couple of approaches:
APPROACH A: Make a space frame of galvanized metal
electrical conduit. Using appropriate lengths of galvinized metal electric
conduit, bend them to the appropriate 1/4 circle radius for
the 'longitudal'/vertical positions - 5 -7 in total. These will be
mounted upright on the interior side of the space frame. Then
bend 5 semicircles of the condit using the same radius plus
2-3in on each end to flatten for use in attachment. These
semicircles will provide a top and bottom and center half
hemisphere locations with intermediate supports between the
bottom and center and top and center. The 1/4 circle radius
arcs used for the vertical/longitudal pieces are spaced out similarly
as the semicircles. Wire tie these together in a criss-cross pattern
or drill holes and wire or bolt together with lock washers/nuts using
the just drilled holes. This results in a rigid 1/4 sphere space frame
based on radial arrangment of the bent conduit ribs set at 90degrees
to each other. but with irregular spaces between the ribs.
AN ALTERNATE way to fasten the bent conduit ribs would be to
do the longitudinal/vertical ribs as described, but bend decreasing
length semicircular latitudinal/horizontal ribs at a set spacing from
the bottom to the top. Fasten together as described. This would
result in a space frame looking like a conventional 1/4sphere piece
of a globe with latitude and longitude lines. The voids between the
ribs would be more regular in shape but decrease in size as you go up.
NOTE:
An additional consideration is how you would attatch the conduit
space frame to the rest of the body. One way would be to
extend the end lengths of each conduit bent piece 2-3in and
then flatten those ends of each of that 2-3in in the same plane as the
wall/roof area they would teminate/attatch at.They could be fastened
together by drilling a hole in the flattened ends and then bolt them
all together at one point [for the radial arrangement] on both ends of
the semi circular pieces, and at the top end for the vertical/longitudinal
1/4 circle radius pieces. How the edges of the conduit space frame attatch
to the mating wall/roof area depends on how those are configured. The piece
abutting the first laminated vertical rib(s) could be fastened with appropriate
"U" shaped long legged brackets ~ 5in long~ with a couple screws on each
leg, one bracket leg on each face of the laminated rib. The curved lower front wall
could be made with a continuation of the verticle/longitudinal front
conduit curved conduit ribs [with a couple more corresponding semicircle cross
pieces] to the floor and their flattened ends bolted to the floor perimeter. Or, to a
semicircular front base made of curved laminated plywood ribs mounted
sideways as bottom and mid level horizontals connected by vertical laminated
uprights. The vertical bent/curved conduit ribs could have their flattened 2-3in
ends act as tenons into the curved laminated horizontals at mid-level or you
could attach the bottom/first semiicircular horizontal conduit rib with the afore
mentioned brackets to the midheight curved front wall top.
To finally form the front top half of the Foamstream body, infill the voids
in the space frame with appropriately shaped pieces of foam board
wired/glued in place. Fill in cracks with a spray foam and trim to as smooth a
surface you can.
A WILD IDEA: [AKA:" USING OUR NOODLE"]
Instead of piecing together various sized flat foamboard pieces cut
for infill why not use a sufficient quantity of those foam "noodles"
that they sell as a child's pool toy or swimming aid, and wrap them
around the conduit space frame 'log cabin, log style' from bottom to
top, Each course length decreases to fit the 1/4 sphere space frame
as you go up. These can be wired to the frame with aluminum
or brass wire and glued together. These foam 'noodles' bend easily and
have a center hole their whole length. They could be cut in half
lengthwise to reduce the quantity needed. Then infil any gaps
with some form of spray foam and fair out from there. You may
even be able to cut a couple of them radially into strips to use as "chinking"
between the "courses". Of course you may need to adjust the space
frame dimensions a bit so that the exterior of the 'noodle' foam covered
conduit space frame merges/blends with the rest of the body walls
correctly.[You could leave the 'corrugated' look of the stacked foam
noodles and just canvas/glue etc. over them for a beehive look -
<Here's a stretch: Scientist have found that such parallel rounded
ridge forms on whale flippers are much more hydrodynamically efficient
that smooth flippers - so would that translate to more 'aero' for the
Foamstream? Ha!>
APPROACH B:
For the front 1/4 sphere shape and semicirclular front bottom wall:
You could also laminate up 3-5 additional 3/4in ribs and bottom wall
pieces and miter them at the top where they'd meet the center "flat
ridge board". Use mortise and tenon joints here too to join the sections
together. - or - use a semicircular 1/4 in plywood "D" shaped 'joining' plate
to join the front radially placed ribs together and to the "flat ridge board".
The tenons probably should be longer and the mortises correspondingly
'deeper' when joining the top curved ribs to the bottom wall sections and
also for the afore mentioned joining plate for the front radially placed ribs
and the front of the "flat ridge board". Fill in the angle areas between
the ribs joining at the top with triangular 1/4in plywood pieces that fit exactly
over and under the 1/4in plywood "D" shaped 'joining plate, and thus make
the ribs and the "D" shaped 'joining plate' essentially all one piece .
And, of course, all the outsides of these joints should be also be reinforced
with fiberglass tape and glue/epoxy.
Sorry this has been so long and 'wordy' - I'm having computer
problems and can't scan or upload/download scans or pics at the
moment so I had to go the descriptive route - hard to be concise
when trying to be precise it seems!
Norm/mezmo
OK, figuring that going with the rounded form , I'll have to do a LOT of kerfing ... :o So came up with a simple guide for the router .. Just some scraps to make the job a little easier ...
image.php
Just so you know, I am stealing that idea. :twisted: :twisted: :twisted: :applause: :applause: :applause: What's the old saying?? "Work smarter not harder"....
Just a thought here...
In looking at many of the pictures, it seems that (even with expansion of the GG), those kerfs aren't getting filled as much as they could.
Just for kicks, what do you guys think about ripping a bunch of strips on a table saw with the appropriate bevel on either side ?
They would follow the curve like the staves of a barrel or the planks of a hull and (most importantly) would allow 100% area for the glue to bond.
Not that your jig isn't a bit o' genius, GPW !
W2 ,I heartily agree about the V shaped kerfs ... just too many calculations for my little pea brain ... and the eventual search for exactly the right tapered router bit ... Cutting on a table saw would be too much for this old guy to handle ... :oops:
Plus the idea of skinning the inside negates the decorative need to have the kerfs come exactly together ... not that it wouldn't be very COOL to have it do so ... 8)
How about the cove and bead router bits like they use for building
wooden strip boats? May make a lot of foam-dust though?
And---
Maybe I'm reading it wrong as mentioned, but shouldn't the kerfs be
positioned to the outside? That gives a smooth interior wall and no
worry about interior oriented kerf edges lining up and such. Then
you'd just fill in the exterior kerfs with some judicious amounts of spray
foam from a can, and then cut/sand off any excess of that flush with
the rest of the rigid foam
Norm/mezmo
