Front window on a teardrop?
amydub
New Member
Joined
Jan 29, 2026
Posts
8
Location
Chelsea, MI
I'm building a foamie teardrop and would really like to add a fixed window to the front "wall" to let in more light. I'm thinking a 12" x 32(ish)" window (seems to be a somewhat standard size for cargo trailer applications) would work without interfering too much with the curve of the front.
1. Am I underestimating the difficulty of incorporating a 12" flat surface into a large curve? 2. Do front windows need to meet different specs that windows used on the sides? 3. How likely is it to catch a rock and get broken?
I'd be more concerned with water intrusion at speed, more than a rock hitting it. Seems to me the tow vehicle is going to be more of a target for rocks, rather than the front of the trailer behind it. Water, on the other hand......
Roger
When I wrote my book, I considered adding a moon window to the project, but they are notorious for leaking, and I didn't want the greenhouse effect. I sure didn't want builders to use my book and find that I had given them a problem.
Keep in mind, there's a reason that diamond plate is frequently added to the front of a teardrop. Rocks thrown by oncoming traffic will be traveling at over a hundred miles an hour when you add in your speed.
Good luck with your project.
IMO, skylights and windows are prime candidates for leaks. I bought a Timberleaf Pika, and the skylight was the first thing I omitted from the build list.
Roger
Ah yes, water. It’s always water, isn’t it? Thanks for the reminder🫠
New posts
