FWIW, here's how I accomplished most of the straight edges on our tear. The one hanging to the right is the jig for the circular saw and the ones on the left are for the router and 1/2 inch straight cut bit. These are for a particular saw and blade, and for a particular router (centered with a cone) and bit.
Start with a half inch scrap of plywood with a known good straight edge. A jointer is probably the best way to get that edge, but I didn't own one so I used a router in a (cheap) table with a split fence. I used a 1/32 inch shim to get the left fence proud of the right fence and then aligned the straight cutter bit's edge with that left fence. Running the plywood from right to left, it takes off just a little bit of wood each pass and after a pass or three you have a straight edge. It mimicks a jointer.
Then, to make the jig, glue a quarter inch piece of ply under the half inch piece with the straight edge along the lip. Make the lip wider than the distance from the edge of the router plate or edge of the saw plate to the bit or blade. Then run the router/saw along and cut the 1/4 inch ply so the lip is just right. After that you just align the edge of the lip with the piece where you want to cut, and it's a quick process.
The half inch scrap should be wide enough to clamp each end without interfering with the router/saw. Also, be sure you clamp the piece you're working on as it might slide under the jig. (Ask me how I know!)
Except when it's easier to use a table saw, these jigs are my preferred way of getting a straight edge on my work. I usually rough cut the piece with a jig saw OUTSIDE THE LINE, and then straighten it with the router. (The jig saw cut lessens the strain on the router bit from cutting a 1/2 inch line in the wood.) I made 5 foot and 4 foot long jigs for the teardrop project. If I need a longer straight edge in my work, I fiddle with clamping the 5 foot jig along a pencil line and get something suitably close.
Getting smaller pieces straight is tricky, clamp-wise, so I eventually used the larger jig to make more straight edges and now have a whole set of smaller jigs with 3 inch increments of length. Here they are in a home-made shelf.
I use the one that's at or just one size larger than the length I want.
I hope these ideas help Sara. Don't give up! There is a solution.
