Galley Rain Fly?
DoctahDeane
Senior Member
Joined
Jul 10, 2013
Posts
259
As I read through previous posts, the Kelty Tailgater gets good reviews but that was mostly 5-6 years ago and they seem to be discontinued. Any new recommendations? The Ez Up stuff looks functional but not lightweight. Would be nice to have something like that Kelty, which looked like a nice design.
I feel you pain. Kelty used to make this one too. It was called a carport and this was the medium size.
image.php
image.php
I used it as a privacy tent in the morning and then moved it over the galley.
I got it in 2005 so the are scarce now.
You might find something on ebay.
We set up a canopy then L and I move it to the rear of our square back. With the edge of the canopy over the top of the back roof we can lift the back hatch. We use a wrap around screen and walls to give a 10x10 room at the back. It makes quite a safe sun, wind and rain shelter.
Tt
We use a Kelty Car Tarp, no longer being made. It is attached to Kedar rail on the top of the tear. This is easy to do with any suitable tarp.
image.php
image.php
image.php
image.php
The "no longer being made part" is the challenge. I'm hoping for something with a nice design, easy up, easy down and that looks nice as well. Looking high and low :D
as far back as 1866 when Charlie Goodnight developed/invented the CHUCK BOX which converted a ranch wagon to a CHUCK WAGON there has been a need for a fly over the tailboard to protect the cook and the process of cooking
this need continued into modern times w/ the advent of the internal combustion engine powered chuck wagons
some of the flies were just the wagon sheet flip'd to the rear of the wagon
i'll be right back
sw
We have two Tailgators, one in our teardrop and one stored away as a backup. They come up on eBay about every six months.
If I were looking for a galley shelter now, I would buy one of these:
https://www.amazon.com/dp/B00ZKYSCO...olid=3DIEP78B3UWPM&psc=1&ref_=lv_ov_lig_dp_it
There are several brands that are apparently exact shelters so prices vary. What I like about them is the fact that they have clips instead of sleeves.
Thanks T - I saw this one poking around. Thanks for the endorsement. Always good to know something works!
some flies were elaborate custom made structures for wagons that set up on ranches at the gather/branding time where food was not only prepared butt served as the center of life when the cowboy wasn't "in the saddle"
as seen above w/ some no longer manufactured/sold solutions most TTTnTD campers not only want the protection from sun wind and rain... they want to make a reasonably artistic statement where their solution is appealing and inviting from a distance
folks w/ TTTnTD's are going to continue their quest of some artistic solution for wind sun and rain protection which will in many cases involve some form of providing privacy
since the chuck wagon was created from an already existing farm/ranch/freight wagon the means of storing and carrying poles was an external appendage of sorts frequently high on the side and consisted of a couple large hooks for racking the poles
IMHO racking cedar or pine poles on the side wouldn't quite be in order for today's TTTnTD's
SO... A solution to the OP's problem must begin in the planning stages of the build
consideration must be included as to how you plan to provide the needed/desired protections and where/how you plan to carry the poles necessary to support the structure whatever it may be/become
another consideration could be how you wish to attach/secure the structure to the trailer if you do
i'm seeing an under floor tray/compartment for the poles a/o the folded structure/fly
it could even be under the trailer frame in the elements ±
RV's use an extruded aluminium track that the awning bolt rope threads thru to maintain a waterproof attachment point on the vehicle
the track can be had by the foot or by pre cut lengths
using the track/bolt rope method would give the fly some added stability
a fly off the side or over the hatch or both could provide the desired protection
most big truck(18-wheeler) tarp manufacturers create custom tarps as their bread n butter
they have sturdy materials on hand and sources for most anything else one might desire
another source is the canvas products manufacturers that supply traditional/historical activities
i will be interested to see what thoughts others come up with
sw
OK, but my original request was all about a completed build and lack of :) I really do like that Kelty Tailgater design and Tom pointed me to the other one, as well. That looks like it'd do the trick, while I continue to monitor eBay for the elusive Tailgater.
sorry couldn't help stirring the pot since there are likely some reading along who might be enticed to try n create some of the stuff that gets suggested here
sw
sw
No kidding! It's essential gear - and also, that's a beautiful short. I want to be there NOW
Graniterich":jb7nkhbf said:
I have one of these. Not the best in the wind.
Texsport Spinnaker
https://www.amazon.com/gp/product/B001A ... g-books-20
Sent from my KFKAWI using Tapatalk
I have one of those as well. The key to using it in a breeze is staking the bottom close enough that it maintains tension on the poles, and of course a sturdy connection to the top. I have the gas cylinders holding up my hatch, so I also have to insert a pole to make that rigid. But you are right, in a stiff wind it’s not the answer.
