Camp4Life":xc8valn6 said:
What happens when you extend the frame past the hubs, is that you exert downward force outside the track width, using the tires as a fulcrum. You might think that it's ok because the other side sticks out as well so it balances out. This is all fine when the trailer is sitting level and not moving. But when you apply lateral force on the trailer, ie; taking a turn, or getting hit by a side wind, the trailer tilts to one side, and now you have the weight outside of the track width adding to that imbalance because of the weight that's being exerted outside of the track width. The further out you're extended, the worse it gets. It's the same concept as basic leverage.
I respectfully disagree with this suspicious analysis and bold sweeping conclusion. If the loads can be estimated with reasonable accuracy, a moment diagram can be solved and that would determine if the trailer will tip or not. Same for the wind statement.
The only two reaction points (if we ignore the hitch for simplicity) are the tires, so that is the only place where "downward force" can be transmitted. In a stable body, statics, loads are directional and lines of force travel along structural axes as tension or compression. In a moment diagram/calculation, symmetrical loads will be offsetting. That's just how it works; the sum of the forces trying to rotate... yada, yada. It's the non-symmetrical loads (wind/centripetal/lateral/traversing uneven ground) and the CG above the ground that matter. (For side hill scenarios we could also get into traction and coefficients of friction, soil analysis, etc.; but let's not.)
The big question is what are the loads and what are the operating conditions. A trailer OEM can't control where the end user ends up putting the load, or what terrain they drive on, so they must design for that factor. That, to me, is a more likely reasoning for why you don't see too many UT's or CT's built much past the outer side wall of the tire. There is also a matter of useful space (ergonomics) and economics of manufacturing.
Look at any semi or deck-over trailer. They all have side walls/decks that or slightly past the outside of the tires.
So I say, if the OP wants to build over the tires, so be it; just analyze the estimated loads, do some math and see if it still makes sense first. If that is beyond their capabilities, then there is always the option of emulating somebody else (many people) who has taken this approach and been successful. If this "doesn't fit in" a particular person's "box", then maybe play it more conservatively rather than less.
