DougN":1f9qqb1r said:Hi Dan, thank you for making this calculator! Question, if I reverse the mount points so the outer mount point is on the hatch and the inner mount point in the galley, will the calculations be the same? Any reason not to do it that way? I read somewhere it makes the hatch more stable, especially in wind.
Thanks,
Doug
, but I have a question.TimmyNY":3dtl8cb1 said:Used the calculator last weekend for my hatch. It worked perfectly. . 31 inch 80 lbs struts that I bought on Ebay. your measurements were perfect. only took 10 min to install them. look for strut-your-stuff-here on Ebay. they have all kinds of strut lengths and weights and hundreds of different brackets picked up everything that I needed for $70.
Tim
ratrod71":2cbbnphi said:Installed the hatch struts finally. Another item checked off the final to-do list. I used 20" struts rated at 100 lbs. Distance from hinge pivot point to upper ball mount is 7.25". I used the hatch strut calculator on this website and it worked perfect. Wahoo! Bryan
ratrod71":3owvldl0 said:Installed the hatch struts finally. Another item checked off the final to-do list. I used 20" struts rated at 100 lbs. Distance from hinge pivot point to upper ball mount is 7.25". I used the hatch strut calculator on this website and it worked perfect. Wahoo! Bryan
