working on it
Senior Member
- Joined
- Oct 4, 2011
- Posts
- 2,208
Ok, my hatch door is as simple as they come...a single piece of 3/4" plywood (49.25' tall x 48" wide) attached with three heavy-duty gate hinges. Add two handles (one inside, one out), two hasps, two draw latches, two flagpole brackets used as prop rod mounts, one tin sign ("Made in USA"), weatherstripping, license plate light/bracket, a weather seal for the roof-side, an LED brake/turn/running light combo, and many coats of paint...it adds up to mucho weight.
From another post:
working on it":3bi8bbg4 said:I've grown tired of using my twin hatch props (awkward to lift, assemble, vice-versa), also because the wife can't do it by herself-unaided-, and on every camp-out, I have to open/close it multiple times. I never could find a telescoping prop rod capable of handling the weight of my hatch (I thought it was only 48 lbs; I was wrong, it's more), or long enough (I open it to 105 degrees, for head clearance). I might use the linear actuator I've found,to be mounted on an off-center inclined base (on the shelf), between the water jug holder-A/C drainpan and the extended-run fuel tank.![]()
- I posted measurements, angles, and proposed mounting photos in my gallery,
- measurements
- where it will go
- but I never actually weighed the hatch at the 90 degree (horizontal) point, much less the actual "proposed" attachment location for the hatch-side clevis. Today, I weighed it at 90 degrees (couldn't do it at 105 degrees, the pole kept slipping); at the chosen attachment point (9.5" from hinge center, it exerted 120lbs of force). I had anticipated a force over 100 lbs, but wasn't surprised. That's why it's a bear to lift/then hold up, and raise 6" more/then insert prop rods in their holders. I moved the extended-run fuel tank over in its mount 1/2", and now have 2" clearance to mount an actuator and angled ramp.
- I figure that an 18" stroke/42" overall length/150 lb force actuator will get me in the ballpark. Design angles/bracket mounting spots/hatch clevis-load spreader will have to be tweaked as I go. I used a gas-spring online calculator to check the possibility of using a single gas-spring, instead, but figured it three ways from Sunday, and it showed me that any spring powerful enough to lift it, would be very difficult to compress back to it's closed position. I will also include a quick-detachable pin on the hatch-side clevis (with built-in "wiggle room", to pull the pin), just in case the actuator breaks or the power supply fails. The prop rod system will also remain, as a fail-safe backup.
