Would you like to regenerate the title as well as the summary?
I still need to do some test on landscape fabric.An overlap on either the wall or the roof is a good practice and critical for my builds. I've done four TDs with the overlap from the roof down about 1 1/2" over the sidewall and have had no problems. My seams show.
Personally, I don't think the seam showing is a bad look if you take the time to cut it straight and eliminate fraying by pre-gluing the seam area before cutting and applying. There are other ways to minimize visibility though I really don't think they are worth the effort.
How do I pre-glue... After installing the majority of the roof canvas leave the flap two or three inches longer than you want it to be when finished. Do not cut to finished length until you glue the top and bottom of the flap with diluted TBII (at least 50/50) in the area where you intend to cut it. Allow to set "dry to the touch" but not completely hard. Mark and cut the excess flap. It is important to glue and allow the flap (and majority of the roof canvas) to shrink before cutting. It will shrink quickly. Perhaps in ten minutes or so. And the roof canvas may shrink up to three or four inches depending on quality of material. If the flap dries too hard to finish use a clothes iron to soften the flap/glue and it will settle into place. Practice this on a scrap piece.
And please note... I do not preshrink the canvas. As it is applied with glue it shrinks and pulls tight in just a few minutes. On each of my four builds it pulled out all folds and creases as it shrinks. Pre shrinking, in my opinion just makes getting everything flat harder as you then need to manually pull and stretch it flat. Give it a try on some scrap to see if this works for you.
Good luck!
Edit... I just noticed your "landscape fabric PMF" post. I have no experience with that material for PMF. I suspect it will not shrink or shrink very little compared to cotton duck canvas. If that is what you are using for PMF please disregard my suggestions.
Thanks for the picture.My side walls wrap up over the roof and around the front and rear. Then the front and rear walls applied not wrapping to the side but wrapping over the roof, finally the roof applied not wrapping down anywhere. The result was seamless side walls, 2 vertical seams front and rear with all other seams along the topView attachment 2524875
Pretty clean, first time I did it so not perfect but if I ever do it again I've got the plan down.
I personally did not like the landscape fabric at all. I wish i hadn't even messed with it. It doesn't adhere near as well as the fabric cloth. As a matter of fact i cut out sections and then used drop clothes. I wish i had used it everywhere. This is just m y experience though.Hi,
To have less visible PMF overlap joint for wall/roof
Is it a good idea to bring the wall canvas (red) onto the roof 2 inch and put roof canvas (green) over and cutted flush to the wall like this
