High Desert of eastern NM
AAAAH, and the drop down weather station, front and center.
Shop for a good model, as this one, every time I get to go camping, the batteries are dead🤬🤬🤬🤬🤬
Then you’ll have to reset the hole d…. Thing😡
Save the directions 😜
My 50 watt flexible Renogy solar panel
I wanted to use a 100watt panel, but it was to large and the fan was in the way.
It was properly set using VHBT, using the appropriate primer, then the forward facing edge and sides were sealed with NP -1, leaving the back edge not sealed , so it shouldn’t sweat, condensate in between.
This will not come off.
Then the ports
Two ceiling mounted led’s, with a high and low.
Even the low is bright
Same lighting that is on the inside of the hatch
The underside lighting
Not visible until you get under the trailer.
I think there’s 10 switched from the inside.
This is I think my fav. Feature 😃
When you have to get up at night, you can safely see at least 25’ in all directions.
Not blinding at all
Not blinding at all
When I get up at night, I don't want that much visibility from my fellow campers! 😂
Tom, if you're that loud to wake them, they should........
Oh never mind.
Shelly sez, there's not much to be seen....
I think that's what I heard:ROFLMAO::ROFLMAO:
