Hinge (and hatch) placement makes me wondering
jongaud
New Member
Joined
Mar 31, 2021
Posts
6
On the picture below you can see (in green) where I was about to place the hurricane hinge. What I fear is that both parts almost horizontal. Could it leak with such placement?
I'm sure some of you will have some insights for me.
Thanks! :)
P.S. I want to place it so high in order to maximize hatch opening (the trailer will be used for camping during the summer but to transport HUGE mountain fat bike during the winter).
image.php
Why not a little further down and lower the bottom of the hatch. Easier to get the bike out.
I had leakage with my hurricane hinge. I just rolled 6" wide rubber sheet over it and that stopped the leak. I used a metal carpet transition strip to seal the edges of the rubber sheet. You can buy these strips at a home center store.
Tt
Looking at a few of the designs of hinge out there Im not sure what there is to leak about the hinge specifically. If anything a more horizontal placement has less of a flow of water crashing into it trying to force its way in. I might be more concerned about its long term mechanical resilience to that sort of mounting due to forces being in a slightly different direction. But that probably depends on which design hinge you use.
With mine, the hinge leaked due to capillary action. The first time I opened the hatch, water from dew dripped inside. Knowing that the hinge doesn't work well on a flat roof I would use an inexpensive conventional hinge if I built the same again.
But in the hurricane's defense, it is nice having two methods of water rejection stacked on top.
Tt
Tomterrific":26l9f4hd said:
With mine, the hinge leaked due to capillary action....
* I don't use a continuous hinge, using gate hinges instead, and there's a 2" gap left between the roof and hatch door when opened. I covered the gap with old conveyor belt material, very durable, but it surprised me at first camp when it rained; there was a constant drip along the covered gap, because the conveyor belt material has thousands of tiny pinpricks in it, probably to let air pass-thru to make it slide on the conveyor surface easier. I never thought about it before.
* I grabbed a can of Herculiner bedliner spray when I returned home, and lightly coated the upper surface of the material. It leaks no more.
New posts
