Next I had to figure out the propane tank.
Bought some hoses to test what would fit. This one didn't work, it was hitting the control panel. I could move it, but I just want to get this done
Waste of time in the end, it appears the attachment point on the Partner Stove has a fitting I couldn't find in town, nor did I have the patience to search online for a part with components I don't know the name of as well as the delivery time. I'd have to make the factory hose work.
I did not want to store the hose in the drawers, I'm trying to free up that space. A thick hose that has a tendency to straighten itself out felt like it would be a headache to pack. I probably spent 4 days while working on other items to think of a good alternative way to store the hose. I initially thought of a cubby, or a hook to hang it off, or some sort of clip but I didn't like any of these for various reasons.
I stared at the hose, and noticed it wanted to be straight. Had a flash of a thought and figured I could take advantage of that property to hold itself together with channels for a particular shape.
This would be a simple way to store it, no moving mechanisms. I like the simple elegant methods.
Here is the little channel. I initially made two
The canary was very strong, I was unable to squeeze these arms and snap them so they should be good enough for the job.
I initially made two, but the brass cap that attaches to the stove was too thick to fit. I did not want to thin out the arm of the wood and weaken it, so I made third with a step in the middle to fit the hose and the brass end
Had to make sure they cleared the gas springs. Juuuuuust made it
Attached the end point, and traced the interior diameter of the hose. Some simple geometry to position the three 60° apart for even pressure on the hose
And it's done
The hose reaches the stove just fine. The attachment to the 1L tank will hang off the bottom of the control panel when the tank isn't in use. I just need to buy a nice brass or stainless hook
And it's done
