Hobbit themed Teardrop
Next up was prepping the steel for painting. I was going to sand everything, but the nooks and crannies were a nightmare to reach. I was rubbing my fingers raw and burning through sand paper.
Saw an old sandblaster on a sheld and that puppy up and running. It was still a time consuming process, but everything visible surface was prepped properly
And, apart from the boot trays, everything is ready
Used some hangers and paddles with predrilled holes to make painting easier. Matte black for chasis and interior components, hammered silver for exterior on the trailer body
It probably been sitting for over a week. The hammered silver is done, the black is still curing. I did thin layers this time, so I thought it wouldn't take as long as the frame, so we'll see.
While the paint was curing, I decided to knock out the next big annoying task - prepping yhe exterior wood for varnishing.
When I attached the walnut trim, I left without scraping the excess epoxy off. This was a huge mistake, the is proving to be extremely tedious. I predict 1 hours worth of work is now going to be 2 weeks.
Started off creating the 3rd brake light mount. This only took 2 hrs
And now, I've been stuck sanding epoxy off the walnut, sanding down the drips (without penetrating the fiberglass underneath), and hardest of all is cleaning up the 90° edges.
I've tried various techniques. I started with brute force chiseling, but this tends to leave a moon-cratered surface and fractured epoxy. Fortunantly this didn't extend to my base coat, which likely has to do with the fiberglass
The best removal method for large drips and squeeze out is heat gunning the target area, followed by chiseling. The epoxy rolls up and away like rolling a tortilla, and the remainder becomes hard again soon after - I don't see any immediate structurla problems or discoloration.
It's taken me 3 days to knock out one wall, so about 45 sq ft out of 190 or so. Tedious work, but I like sanding and chiseling so it's still a good time.
Been a minute since I've replied. Between work and 2 school bus conversions I've helped build furniture for, it's been tough to make time for my own project. Getting back into the swing of things
Took a few weeks of tedium with the time I could squeeze in to remove all the epoxy drips and trim up the walnut edges so they get a good soaking from varnish
Once that was complete, I found a plethora of walnut that did not have contact with the birch. I spent event more time sanding these thin voids (My fault, I did too much too fast when attaching these pieces....) Then, using more epoxy mixed with some brown pigment, I filled in the voids.
I also reattached some 'danglers' that broke off when mounting the trailer. Various forms of methods to apply pressure were needed
I also epoxied on the third brake light mount, which also received (4X) dowels to add strength.
And, finally, attached the remaining pieces for the door trim that will fit around the door hinge.
You can see some of the fresh epoxy spills I have to clean up.
Not shown is even more cleaning up of the brown pigmented epoxy. Ugh...... but it's done!
To break up the monotony, here's a cool photo of the trailer lit up in a dark environment. It makes me excited to be nearly done!
Moving onto to the tongue box!
The wooden box I built didn't seem like it was going to work. Very heavy, incorrectly sized, and so on. Just decided to buy a tongue box and be done with it
When I built the tire swivel arm, I figured it wouldn't be a problem to find a tonguebox that could fit.
Taking some measurements.....
I could only find one.... so I ordered it. And they shipped it loosely in a carboard box with a pittance of the thinnest foam available over the lid..... Of course it shipped damaged
Here is the packing material....
It suffered two major drops. Very dissapointing, especially after spending $260 on it. Seemed like a good product otherwise....
I guess I'll make my own. At least I have a good reference piece. Found some free steel, I began to sheer it and bend it
Throw in a couple of tacks.... and it's looking good!
Got some more TIG practice in. I think I'm getting the hang of it.... much more enjoyable than MIG. Looks pretty good compared to the professionally made counter part
Used a jigsaw to cutout the the latch.
Just waiting on some piano hinges to arrive
While in the TIG phase, figured it would be good to tackle the two super-extension drawer slides. They do not have a gas spring like the soft-close slides, so they will not hold themselves shut while driving.
I wanted something that would automatically lock when closed. I wanted to avoid the public bathroom door style that required manual manipulation to open and close. I had some fun building these satisfying spring loaded latches to hold my oven and cooler in place.
Working on the oven, taking some measurements
Buy some metal, draw some lines...
Build all the individual pieces....
Bing Bang Boom, you got a spring loaded latch.
Here it is ready for installation - just needs to get powder coated
The cooler, being much heavier, needed something more heavy duty. Built a gate-style latch
Some of the pieces......
And it's installed. Works perfectly
They make very satisfying sounds =]
Been saying this for a year now, but I'm nearing the end.
I riveted the handles for the boot boxes on
Then I did some hunting for a handle for the galley door. I couldn't find anything I liked aesthetically. Figured I'd make my own, with a corner attachment for extra strength. I was thinking of something shaped like the pillars in Moria
Started by chopping some thin steel. Some simple geometry allowed the 45° ends to be cut right in the middle
To achieve equal spacing in the staggered stack of chevrons, I made some spacers that were 1/8" different in depth.
Drew on the handle where to grind, and took my time using a die grinder
Running a test fit, trying to figure out exactly how to do this...
Welding on the non-visible portions. These will be hidden behind the next stack.
And the hard part is done.
Added on the base for attachment
Looks pretty good when it's attached. The two planes for attachment felt extremely sturdy - should hopefully eliminate any torque
Started finishing up some other lingering tasks. The tongue box needed the piano hinges and the catch for the latch welded on. Both of these were welded on
The pin for the piano hinges became a problem. The heat from the welding caused deformations in both the lid and the body, so alignment isn't that great. The pin no longer fit in, and forcing it in with a drill (spinning helped it glide) caused the pin to break in the middle in two places. I spent the better part of 2 days getting it out without damaging the box. The pin was 1/8" in diameter, so I bought a 3/32" stainless steel pin. Hopefully it slides in easily, especially with the thickness that will come after powder coating
Here's my current to-do list. It seems to always grow once I move onto the next item.
1) Trim and re-weld tongue attachment for spare tire
2) Secure Battery
3) Create pathway from battery to trailer interior
4) Create boot box door strike
5) Build drop-down attachment for galley draw latches
6) Install frictionless sliders for boot box
7) Trim boot box spring latches to size
8) Install trailer light wire system
9) Prep trailer for varnishing (sanding, cleaning, etc...)
10) Varnish
11) Attach trailer to frame (drill holes, seal, etc...)
12) Create keyhole for a cam lock so the doors can be locked (still considering this....)
And that should be it. Feeling mentally stuck on creating an electrical pathway from the tongue box to the trailer body - unsure of the best method to take. I've never really 'plumbed' before
Consider Sealtite conduit and connectors. I was able to use a couple of different PVC female threaded connectors embedded into my tongue box and the underside of my headboard cabinet bump out to get a flexible and water tight "pipe" for all of my tongue to cabin wiring... which is everything except electric brakes. Available at big box hardware stores.
Appreciate this, feeling less stuck now.
Working on the tongue box.
Hated to do it, but I had to grind off some of the paint and metal so that the tongue box sat flat
Built a wooden try for the battery. Fits like a glove. Should protect the powder coating on the tongue box interior and on the battery
Since I had some space in the tongue box remaining, there were two spots that could just barely fit two spare coleman propane tanks.
Sizing it up!
Also checking for placement of the arms that'll hold the battery down - can't have those taking over the propane tank's space
Welded on the battery attachment arms ancors (I don't know what to call them). Kinda screwed it up - fortunately only the rear of the tongue box looks funky. Welding in such a confined space as not fun - would have been better to drill holes and fill them in to attach them.
Anyway, was left with less space than I hoped for. Sanded down three walls just a wee bit to allow the propane tanks to fit.
Figuring out how the battery attachment arms are going to fit...... shaded in the area to remove. I took care considering this - the direction of pull will be slightly towards the middle of the tray. This way, it's pulled more downwards and less backwards, which should prevent the battery from tipping
Created a trim guide to remove material. Needed to be be done because a router is the only way to do this without removing anything more than necesarry
Now, working about the wire feed. Following KCStudly's advice.
Created some gaskets using hole saws
Also made some washers out of stainless steel. The hole saws cut the internal circle out no problem, but I burnt through two of the hole saws cutting the outer-diameter. The teeth simply ground flat, not sure what I did wrong. I used the marks I made onto it as a guide and ground it down on a grinder
Cut a hole in a mock floor piece to test the size. The only male-male connected I found was slightly too long, so it needed trimming
And it's a good fit.
And lastly, built the door strikes for the boot boxes.
Where I needed MIG to weld the interior for the tongue box (causing ridiculous warping) , used TIG on these. There was no warping, everything turned out great
Now I'm just waiting on some equipment to arrive. Order a Victron smart DC/DC 30A charger so the battery can be charged from my truck. I need to figure out how to fit that, a breaker and a master on/off switch in the remaining space in the tongue box. Also need to fabricate the battery attachment arms.
Few things left to prior to varnishing
1) Fabricate attachment points for the galley door draw latches
2) Test cam locks for galley door. Drill holes if they work. May require creating custom cams
3) Drill holes for main wire in tongue box and trailer body.
4) Complete galley trays
I think that's it?? We'll see, feel like I'm missing something....
Just knocking out some tiny things...
Made some attachment points for the galley draw latches. This will allow the draw latches to attach to the metal frame
Also ground down my spare tire holder - somehow it doesn't fit anymore...
And finishing up the galley tray holders
Here was the current state of them
Cut the remaining holes out
Router and chisel out some grooves for 'legs'
Glued
Attachment points for the legs so the tray doesn't fly away
And it's done.
Waiting for some supplies to arrive. Got some vents to install on the tongue box so the battery and charger can get some airflow to drain heat. Waiting for the DC/DC charger to arrive as well, going to need to weld on some nuts so it can be attached to the side wall. Few new metal pieces to paint up. Then I think I can start varnishing??? Got a family reunion coming up (Epifanes varnish doesn't require sanding between layers, so I got to time it right), so I'm going to start on the small interior pieces that don't need so many layers for some practice =]
Finishing up portions of the tongue box.
Figuring out the placement for everything...
Easiest way I found to attach the master switch, breaker and DC/DC charger with long weld nuts.
Made some jigs to line everything up
And it's done. Hooray
Working on getting the locking mechanism up and running. First had to drill a hole for the lock.
Tried to use a 3/4" bit, but it snagged and ripped the steel. I see why hole-saws are a thing. Finished up this hole with a die grinder
Used the hole saw for the rest. Easy peazy
To reduce the length of the cam on the cam lock, I extended the length of the handle.
I ran a test of the cam lock, and the entire lock was rotating, not just the keyed portion. I needed to add stoppers on the side to prevent this rotation. This would be a very tiny weld job
Here's the piece that needs welding
Simply turned the voltage very low, and took my time attaching it.
Running a test. Here's locked
Unlocked
Here's the outside view. Seems to work just fine. I'll have to make some custom cams but the lock is done =]
The cam lock was a bit wiggly, so I built some new cams with flattened tips that will hold themselves flat. No photo unfortunately
Sanded the doors in preparation for varnishing
Had some epoxy rip-out from when I needed to drill the holes. Sanded those areas down to the wood, reapplied the stain and re-epoxied them. This time around I made plugs to prevent the epoxy dripping down the holes so I didn't have to do this a third time
Pale areas are where the epoxy detached from the wood
Problem areas are sanded
Stain applied, allowed to dry for 1 day (water based stain), then epoxy applied. The 'plugs' were steel rods wrapped in blue-tape (didn't have any rubber plugs), tapped in gently with a rubber malet
plugs worked well!
Cleaned and finished door, ready for varnishing =]
Finishing up some metal work
Trimmed the boot box locks to size
Open...
Closed....
Before I get the metal painted, I need to finish the electrical. I probably spent too long thinking about this. I didn't like the untidy look of wires simply dangling below the frame. If I had made this frame out of C-channel, I think the wires would be protected by the frame, but out of square channel I thought I needed more protection. I go on some very sketchy roads with my rock hunting hobbies, so I wanted the wires to be safe from brush at least. Settled on using tough flexible conduit with various attachments to keep the wires protected and the frame, where holes are drilled, protected from water.
Only managed to get one hole cut and tapped. Predrilled with 1/2" vortex bit, widened to 11/16" with a step-bit, then tapped with 1/2" NPT tap.
Tapping with a guide
And it looks good =]
Pretty tough getting these holes made with so little space. Would have been easier doing this before mounting the trailer!
Cables feel stiff enough that I think a single clamp on every rib will be enough to keep everything in place.
I think this wiring diagram is correct..... Hopefully it can help someone out in the future. Purple = brake-only
Tapping the holes with a 1/2" NPT tap was very tedious. The tap is tapered, so it never gets easier. This also means you have to keep checking to see if you tapped deep enough, as the female end pieces seemed to vary which could result in loose attachments. Throw in working upside down with limited space, and you'll be in for a long ride.
State regulation stated the rear light marker should be placed as far back as possible. This means tapping 3/8" steel for me, not the 1/8" everywhere else. Ugh...
Those took 2 hours each. Very tedious......
Threw on the wall outlet with the 12V adapter. Seems to work fine! Nice and bright
Handy dandy 'glands' to water proof the entrance of wires. Bought some special ones from McMaster Carr that have two perfectly sized hole entrances.
Cleaning up the sharp metal shaving from the interior with a magnet. Quite a lot!
Bought a junction box, drilled some holes and tapped them as well. Plastic was a relief to tap, easy to keep the tap straight. Fitted a hose connecter, which will run a line from the battery box to the trailer interior, and a gland for the 7-pin connector
The rear brake lights need to be run through 4 holes. You can see the bumper has a 1" segment that attaches it to the frame. Those holes I was unable to clean up and remove the burrs, so I found some plastic grommet like things that will push in and stay put. Should keep the wires protected from the metal edges
Did some careful measuring and drilled a hold through the trailer interior to run the wire line to the tongue box
Took about 3 hours to weld this thing togethor - it'll serve as a mount for the junction box and as a shield to protect it from projectiles
Cut some holes to wires and conduit to run through. Rest assured, that hole saw is not red hot, it's just painted orange.
Doing a test fit, looks good! Swapped out plastic elbow for metal due to lack of space. Hard finding pieces sized correctly, ran out of room quickly with the V-beams of the trailer frame
Sized up, cut and ran all the appropriate conduit. Tapped holes as every conduit and frame intersection to hold everything on securely. Figured properly tapped holes would make a better fit than self-tapping screws, don't know if I'm right about that. Regardless, I'm just going to rivet everything on, no risk of anything coming loose that way
And I think it's good! Only attached a single clamp to hold the wires up in the middle, they're holding themselves straight all their own otherwise. Small junction boxes were place as well near every intersection. Although it'll be a tight fit, I should have enough space to crimp everything. I hope so......
Rear
Front
Now..... I must take it all down. Prepping for varnishing, I'll have to jack everything up and separate the frame from the body to ensure proper coverage, and I can't have the conduit in the way. Apart from buying all the interior stuff like a bed and kitchen supplies, the electrical appears to be the last thing I'll do.
Coming up is a bit of sanding on some spots that need it, shouldn't take more than a day or two. I'll clean up my art studio, and start varnishing!
I've got to weld on attachment points in the tongue box for an overlooked shunt (woops!), which measures the state of the battery, and widen a hole I cut to an appropriate size to accept a gland for the cables that will charge the battery. Then, I think I'm actually done with metal working, so I'll send it all in for powder coating. Few spots of metal to cover up again with Rustoleum as well..... shouldn't take more than a day to apply 2 coats. Also got to run a wire from the alternator to the tail of the truck. And a brake adjustor thingy..... We'll see what else I'm forgetting...
