How is my electrical diagram?
italianub":t6m3242x said:
Yeah I agree about the coffee... but unfortunately I am not the boss when it comes to that (I don't even drink coffee!) so I have to appease the better half hahaha.
Well, the physics says you probably will simply not be able to do it. Your battery holds so much energy, and it takes so much to make hot water. The inverter can only pass so much energy through it at a time.
Bruce Osborn, on this forum, built a humungous electrical system that he says was motivated by the desire to heat a mug of water. (Please correct me if I remember that wrong, Bruce.) But that's his hobby and there is a considerable amount of space devoted to batteries and the electronics necessary to keep them happy.
For grins, I could try going through the numbers (after I've had my coffee!) I don't want to sound pessimistic, but facts are facts.
Yeah, I get it, but I have to keep up appearances that I'm trying :LOL: :LOL:
Sure! There are many of us who need our cup of coffee in the morning, and have looked at this problem in regards to camping. Shelly and I have a 120 vac coffee maker we use when camping with shore power. For other times, we've tried presses and pour over systems but find them a pain to clean out.
I surprised myself that I can make percolated coffee that tastes really good (still requires cleaning out later of course, but the basket is wider than most other systems and the coffee isn't as compacted). So we're going to try that next time.
Just some other ideas to consider.
The one big thing I don't see is the 120V battery charger. Make sure you wire the 12v side before the main shut off so when you shut the main off, it will still charge when you plug into shore power. Same goes for the solar charger. I don't have a wiring diagram of what I did but this is it what it looks like.
image.php
image.php
Do you mean a charger that uses AC plug to charge the battery? If so, I have one that will be in the trailer but not always connected, only when I have some shore power. If you mean something else, please explain (total electrical noob here!)
Tom&Shelly":fi87k7tn said:
There aren't a lot of things these days that only require the energy in a teardrop size battery that are just made to run off of 120 vac. Since there is a conversion loss in the inverter it's usually more efficient to buy the 12 volt version.
I still run everything I can at 12V as it's always the most efficient. I consider the inverter in the van to be a total luxury; it's awesome for running the Keurig, induction cook top and a microwave. We even use it to for the water heater. BUT, all our essential services are 12V: fridge, CPAP, lights, diesel heater, TV, etc... We carry a small butane stove to back up the induction stove top if the battery is low. Everything else the inverter runs we can do without in a pinch. I wouldn't have added an inverter in the van at all except I wanted to try the all electric approach, the trailer that has propane and I haven't used the small inverter in it for about 10 years.
P.S. The all electric approach is awesome but it's expensive, everything gets big quick!
Alright, new updated diagram, thoughts?
I might put a 120v battery charger in there as well for when I have shore power, but I already have the charger so I can just put it in if I decide to use it. Not pictured is the shore power plug that I will install, but not connected to anything except a power strip in the galley.
You guys are awesome. I start my build in 2 weeks!
I don't know which battery monitor you have but my AiLi meter (that I really like) shows juice going in and out. So the shunt should also be downstream of the solar controller. Just run your negative to the negative bus bar.
The other thing, is that one cabin and one galley light works fine. Teardrop cabins are small. ;)
I ordered two of these monitors, one for in and one for out - should I return one? I didn't realize they could do both!
https://www.amazon.com/gp/product/B013P ... UTF8&psc=1
I am going to have two lights in the galley and two in the cabin. I know one should be fine, but my brain needs symmetry! hahaha
Typically the master switch only connects to the positive side of the battery. No need to switch the negative. Most people are putting a double pole circuit breaker between the solar panel and the controller. This breaker DOES switch the positive and negative wires.
This diagram is very helpful.
If I was to add a AiLi Voltmeter to the system, where is it connected? And would it need a shunt?
Scott
Scott, you do want a shunt. I am by no means an expert on this but this is what I followed on my build:
This is an electrical diagram from one of Flboy's (Don) builds. The shunt is shown on the right side of the picture about half way down (look for word Victron).
image.php
This is a picture of the instruction sheet that came with my Aili meter.
image.php
This is the Aili monitor that I purchased and it came with the shunt.
https://www.amazon.com/gp/product/B07FG ... =UTF8&th=1
Hope this gives you a little help. I will attempt to see if I can find a picture of how I connected mine. My shunt and buss bars are blocked by my batteries now to be able to get a decent picture to show you.
Best wishes,
Harry :)
New posts
