How many bolts?
dio449
New Member
Joined
Jun 16, 2018
Posts
4
I have searched through the forums to determine the best way to attach my cabin to the trailer frame, and I've seen many discussions comparing bolts to screws. I have decided that I am going to use bolts however I would like to know how many bolts I would need to make a solid connection. I am planning to weld tabs along the two main rails and then some more on the cross members. I was then going to put 3/8 inch carriage bolts through the tabs with a large washer on top and a lock washer underneath. The floor is going to be 3/4" plywood. The question I have is how many do I need, I was planning on 12, 4 along each side and 4 down the middle.
here's a pic of the frame
I that enough?
I used 6 or 8- 3/8 grade 8 on mine, it has worked well for me. I have to be careful; 42 years at a "Cat" dealer; I want everything stronger, heavier. I have to remember, I'm not building a house, just a place I can wander and sleep in. Coyote
Ok, thanks everyone for the quick replies.
I think I can match the consensus with 4 tabs along each side rail, with regular carriage bolts. So a total of 8. I may consider a higher grade bolt as the cost difference for eight can't be that significant in the grand scheme of things.
Thanks
noseoil":1b6lzc32 said:
Grade 5 or 8 isn't really necessary for a light trailer & is a waste of money. The single-shear value of a single 3/8" grade 2 bolt is over 4000#, so one bolt would be fine...
https://www.nucor-fastener.com/Files/PD ... rength.pdf
  • I used eight 3/8" carriage bolts to attach my initial 1/2" floor (12 year-seasoned Birch plywood) to the crossmembers of my trailer, countersinking the heads a bit, but still leaving sufficient plywood underneath, for strength, while using PL adhesive between frame and plywood.
  • Then, I covered that with 1/4" Luan, glued on with Titebond 2, and used small Tek screws thru both layers of wood, and into the metal frame itself, around the perimeter, to ensure that the edges would never lift up from the frame (if I had a delay before building the upper structure). I see no way that the frame and cabin will ever part! http://www.tnttt.com/viewtopic.php?f=35&t=68349&hilit=tek#p1202710
If your using carriage bolts, see if you can't find some proper torque washers:
I think they help strengthen the connection.
I used 13 on Rose, for several reasons. I had the bolts already. The holes in the frames were already there, so I used them. The way I extended the frame I wanted to be sure all was tight, so the cabin is really a part of the structure.
I use 24 elevator bolts.
I weld a 45 deg. gussett at every corner and bolt it down and one in the center of each cross member.
It may seem an over kill to some but I sleep well knowing it won't come off or shift.
:D Danny
I used 24 grade 5 with washers and lock nuts. Probably overkill, but peace of mind.
  • Torque washers make a very strong connection, but I was using materials and methods I was used to in assembling my trailer. As a mechanical troubleshooter at work for many years, lifelong automotive enthusiast/car builder/racer, and self-proclaimed redneck engineer, I trusted bolt-together construction, using steel hardware everywhere. Bolted, of course, functional, and exposed as a sign of the hardware's strengthening presence.
  • I believe in over-kill construction: why use a # 6 or #8 woodscrew to fasten a critical area, where 1/4" or 3/8" bolts could do a better job, with no chance of being pulled or shaken apart? Doubling-up on fasteners, and using twice the normal amount of adhesives and caulks, too, became my method of joinery, except where disassembly might be needed (I.e., for removal and replacement of A/C unit, or a broken window), might be needed...otherwise, it was built to never come apart.
  • I used 8 carriage bolts w/o washers (or torque washers) to fasten the sub-floor to the frame, but topped that with the Luan floor, whereupon I used 36 or 38 flathead Tek screws thru both flooring layers, directly into the frame perimeter, to do the real work of securing the floor to the frame; the carriage bolts were just an intermediate step, PL adhesive under the sub-floor, on every underlying metal portion of the frame, was the first step. Once the floor was finished, the upper structure also was built using PL everywhere wood was joined to wood, and alas mechanically held together with steel angles (gusseted), and heavy corner plates. Instead of using torque washers (or threaded inserts, which could get pulled through), I used oversized stainless fender washers under both carriage bolt heads (with a few exceptions, in non-critical areas), and/or the loctited acorn nuts (or ny-locks, where their use was indicated). PL adhesive was also used inside the bolt holes, and under the washers, for added strength and waterproofing. I can't see where any part of the TTT can ever come loose, unless forcefully, intentionally, disassembled.
I did four (4) 3/8-16UNC bolts at each xmbr, kind of equally spread across the floor area. In retrospect, I would have omitted all of the ones 'in the field' and just gone with the ones around the perimeter. Four up each side and two more each along front and rear xmbr.
Some people will feel this is excessive, but the box is where the stiffness comes from and I want my trailer frame to stay with the box to avoid any relative motion (flexing, chaffing) that might otherwise cause wear through the moisture barrier.
Your plan to weld on tabs for bolts made me think of our build. We thought up an even more time-consuming and difficult approach. We drilled smaller clearance holes up through the frame tubes going through both both top and bottom, and them came back and enlarged just the bottom holes with a Unibit to be about an inch so we could get the lag screw heads through them plus the socket to tighten them. It worked great but wasted a ton of time. Awful job that filled my shop with metal chips.
Later we screwed on a small floor for the galley, and just used self-drill, self-tap sheet metal deck screws with wafer heads. You can find them on the web or at a hardware store, sometimes called deck screws. Worked great, and they were so easy to install we put in a few extra just to be sure. Next time we'll screw down the main deck to the frame with these.
The two little tabs above the drill point clear away wood but shear off when they hit the steel, so you get a perfect clearance hole in the wood automatically. The low profile wafer head pulls down flush into the plywood then stops without pulling clear through. Drive them straight down through the plywood into the steel tube, no drilling required. Quick, easy, cheap, strong.
3JGX7_AW99
I realize this is an older thread, but I would be concerned about the brittleness of these screws. Similar to the concern about using drywall screws for wooden structure, they (dry wall screws) are brittle. In order to drive easily they are thin, so they must have a relatively high yield strength. Er go they are likely to be more brittle. This is fine in a relatively static environment, such as a wooden or steel house stud wall, but might result in issues on a more "dynamically loaded" trailer floor or wall.
Just saying, what is the intended application for this type of scew, and is that comparable to our end uses?
Might be good in the long run, but good to double check.
"Looking at your photo, I think that no more than 10 bolts will need to install the cab on the trailer. However, I think threaded rivets would better suit here. Has anyone told you about them?
The installation technology of rivets is really simple. You can master it without much experience. This can be done using a specially designed rivet tool. The bolt needs to be screwed into the riveter to start the installation.
The rivet bolt has a reinforced flange and an elongated thread, which makes it easy to put it on one side of the connected products when it is not possible to use the second side.
This approach to the choice of fasteners does not deform the surfaces of materials at all and does not contribute to their discolouration.
Such a fastener element as a rivet bolt is made of several types of alloys, of which aluminium alloy or galvanized steel of white or yellow colour can be most often found.
For the automotive industry's installation of rear-view mirrors, dashboards, cabs, and spoilers, it is impossible to replace the rivet with any other fastener to provide the required parameters, both load and aesthetic."
New posts
