Members are discussing the optimal way to modify a 5x10 trailer frame, focusing on whether to cut off the existing metal fender, install a longer axle, or build around the current setup. The original poster is considering options after acquiring a trailer and stripping it down, seeking advice on maximizing interior space and practicality. Several experienced RVers recommend cutting the fender metal and installing a longer axle to allow for larger wheels and a wider cabin, with one citing a...
More...
Members are discussing the optimal way to modify a 5x10 trailer frame, focusing on whether to cut off the existing metal fender, install a longer axle, or build around the current setup. The original poster is considering options after acquiring a trailer and stripping it down, seeking advice on maximizing interior space and practicality. Several experienced RVers recommend cutting the fender metal and installing a longer axle to allow for larger wheels and a wider cabin, with one citing a 74" hub face as a good reference. Others suggest creative alternatives, such as raising the cabin floor to the fender height and using the space below for storage, similar to a motorhome basement.
There is some debate about the feasibility of a longer axle, with concerns raised about the structural requirements and potential de-rating of custom axles. The consensus leans toward either upgrading the axle or integrating the fenders into the cabin design, depending on the builder’s priorities for space and ease of construction. The discussion also touches on the importance of considering weight and structural integrity when making modifications.
