Is a tiny house on a HF frame possible?
Senior Member
Site Team
Joined
Apr 13, 2004
Posts
19,202
So here's the question of the day...
Is it possible to build a tiny house, on a harbor freight trailer? tumbleweed style?
http://www.tumbleweedhouses.com/
Granted we are talking about a radical downsizing from the tumbleweed style homes... and it'd be a single person dwelling... but is it even possible?
Pics and suggestions are welcomed....
I can't see how given the weight limitations of that trailer. I'd recommend getting a more robust trailer.
I would say yes but only if the tiny house was not towed far. Once it is at its permanent location the trailer frame can be supported with a sort of foundation. I don't think towing is a first design consideration with tiny houses.
Because you asked this question I wonder if you have thought much about what you will need to build. It will be more of a tiny standy inside rather than one of the shrunken designs you've referenced. The heavier materials and height of a tiny house design may impact just how light a trailer you can use.
T
House **** I put a whole barn on a 5 x 8
image.php
only if it weighed less than the rating of the trailer fully loaded. The frames on those shouldn't be trusted with much weight, let alone the axles and wheels.
Yea, I gave it some more thought...
A tiny house requires a kitchen, a bathroom and a bed, and a dining room table...
Since building up on such a narrow trailer is not safe, the only option is to build lengthwise.
And the best I could do is this design...
And yes, I know, it doesn't look anything like a small house...
Now I just have to figure out if modifying this into a small house adds any benefit...
P.S. And if I want to add a shower, all bets are off. Back to the drawing board...!
P.P.s. This is the smallest one I could find...
I think anything "house-like" would end up in the 1000's of pounds. The "tiny houses" on wheels are travel trailers with heavier stuff in them, like porcelain toilets, and tile floors. I think a light one would be 10K lbs.
MIke,
in and of themselves TIny Houses are a good thing, but as Bob has shared with us, most communities are not willing to embrace the 'less is more' concept. I think what you shared here is about the 'smallest' you can put on a HF trailer, true, it has 'the basics' including a porta pottie. Once you build one, you still have to have a spot to Use it. Solve That problem and design then becomes the easy part.
Great post because I'm doing this now with an HB trailer bed said to carry up to 1,720#. Here is my post from a recent thread here not yet answered. (New to site).
I have materials in my garage ready for application to my 1,720# bearing trailer bed. I have pressure-treated lumber to carry the cantilevers beyond the steel frame and 3/4" regular plywood. I've counted my base lumber to be about 400#! I intend to make the walls using steel framing (1-5/8" studs & track using hurricane straps at the roof eaves, rigid insulation, marine-grade 1/2" ply outside w/building wrap and metal sheeting, 1/4" beaded waitscot inside).
Am I making huge mistake adding this much load in framing and flooring? I like the idea of the weight and security at bottom with lighter above. I read that steel studs weigh 2/3 that of wood... not so great a savings comsidering their being more timely to construct.
This won't be a travel TinyHouse. Just has to make it down 200 miles to my land where I intend to move.
Would love ideas....comments on this because I really want to start this week and wonder if I should exchange my wood for thinner ply and maybe go with all metal framing.
porta toilet could be sitting inside a shower pan, less stink in the house if its vented too. Then you get the shower and the toilet in the same location, and only need gray water tank.
Mike, you've resurrected the Kamp Master! lol
Guys ... I don't want to sound like am armchair snob ... but there are Tiny Houses, and there are RVs. And (as you all know), you don't frame, side, roof, wire, plumb or finish the two the same way. Anybody every try to wire (at all to code) a 2x2 stud frame with a 2-gang GFCI outlet and 3-way switch? Good luck!
Building a lightweight RV is one thing; building a lightweight "house" on a Chinese farm trailer will violate every code in the book! :frightened:
If you just need to move a Lilliputian Tiny House once or twice in rural country ... why not build it on skids? If you want a mobile residence, lightweight, on wheels, with the bare necessities - well, you've just invented the RV! :LOL: Or at least a cargo trailer conversion.
New posts
