A member building a hybrid foamie and plywood camper pod asked about isolating through-mounting holes with polyurethane bushings sealed in epoxy, plus using EPDM or neoprene tape between the body and trailer frame to reduce wear and vibration. The goal was to keep the removable pod protected from crushing, abrasion, and vibration without permanently bonding it to the frame.
Another member with a similar foam and fiberglass off-road pod described a possible approach using a flexible adhesive...
More...
Another member with a similar foam and fiberglass off-road pod described a possible approach using a flexible adhesive such as OSI QUAD MAX on the frame rails, cured against a parting film so it bonds to the frame but not the pod. The same member also considered temporary shims, flexible bolt bushings, and rubber washers. The original poster concluded this could provide rub resistance while still allowing the camper body to be removed, but no tested results or clear consensus were reported.
