Does anyone know of a source for laminated foam panels? Prefer fiberglass but will consider others.
Like what Runaway Campers uses, or something similar.
Located in central Indiana, but can travel a few hours.
don't buy the epoxy bs make you own. be so much better with woven and MAT no big fill like epoxy crap. .You can use ploy resin with home depo foam .ico foam . with out all the epoxy crap we do a 5 by 10' 1'' RIGHT FOAM about $110 US. . Lay up on 5/8 melamine . . do a 2 part lay up get a convect panel that will build a pod that will last over 100 years easy. the first picture is ploy resin and ico foam . anyone tell you it eats it are liars are a fool
