today I've returned to frame works to address entry step as my folding design requires it to be permanent part of entry door. I am re-using original coleman trailer step, i had to cut it to fit for permanent place and need to add some more sheet metal on the sides to seal the compartment as it will be part of trailer interior space. I think it is going to work good and it could be the easiest and light weight solution, the sheet metal is light gauge and after my cutting the reinforcement happened to be just in a right place under the step area
I will then put carpet on sides and maybe rubber on the step.
The big question is should it be permanently welded or should it be bolted/screwed??
in case it is damaged or bent, it will be easier to fix when it is bolted/screwed... any ideas ?
, well.. not really, I'd rather stick to the well-known approach of "looks about right"
. I am thinking to use Great Stuff for the kerfs as a glue, it should make for a strong curved panel and fill the kerfs good.
