kipa
Advanced Member
This is my idea for a more EV friendly trailer.
Design goals:
Sucking at using CAD programs that never seem to do what I want, this is the model I built 1:12 scale to test my ideas. The outside dimensions without the tongue box are planned at 6x10'.
Now that I look at this photo, it's looking a bit like a coffin. Won't paint it black or brown I guess.
The wedge cover is currently set to taper about 6 degrees down toward the back from 24" to 18" at the rear of the enclosed area. I may try to do more than that, but I don't know the drag improvement would really be worth giving up the space, as the open rear cargo area probably needs to contain items that high anyway. Raising the front would just be increasing my frontal drag area, so I think this is a good happy middle ground that will give me over 7' of standing room under the peak.
The tongue box will be closer to 30" deep since the A-frame of the trailer imparts a drop from the platform. 3' long and 6' wide, tapering to 2' wide at the front..
I do not have a plan to build in a galley at this point, but it may come later, likely on a pull-out if I do.
Also, pay no attention to the wheel well positioning. It doesn't match the trailer base and I don't have the exact dimensions for where the axle goes yet since I am waiting on delivery. Obviously, there is a lot of flexibility to move as needed.
I am thinking that I will also incorporate some storage within the frame, as I intend to sheet the underside anyway to better clean up the aerodynamics. Likewise, the rear end cargo walls won't be solid on the very ack, but rather likely rails with plenty of tie-down options.
I may be able to go a little wider to better match the tonneau cover, but you get the idea.
So, without violating the design goals, what do you think?
Design goals:
- Minimize aerodynamic drag to maximize EV range. The primary idea is to build something that will not cut my EV range by half! If I can keep it under 30%, I'll be happy. Under 20%, ecstatic. There's really no compromising on that issue for me and anything taller significantly impacts that.
- Fit a queen mattress. I like big beds and I cannot lie. Planning to orient it lengthwise since I am taller than the box is wide.
- Fully loaded weight of under 1500 lbs. Weight is an arbitrary limit for keeping it legal without registration here in Oregon. (I could get by with higher, but I doubt it will be even close to that maximum full loaded.)
- Woodless construction for maximum moisture control. I am planning to go with 100% foam and PMF for the entire lower body and front cargo hatch. I also have a full size long bed pickup hard shell tonneau cover for the topper. Similar to the model, it will overhang the lower structure for excellent water shedding. It will also provide for extra cargo capability on top if I really need it.
