Lowering a 5x8 Northern Tool Square Drop Trailer
Thread Summary
Summarized on:
Original Member Title: Mount Northern Tool Axle On Top Of Springs or Smaller Wheels?
A member is building a lightweight 5x8 square drop on a Northern Tool trailer for a 2023 Honda CRV and is trying to keep the camper roof at or below 65 inches without losing interior cabin height. The main options discussed were using 10 inch wheels, staying with 12 inch wheels and mounting the axle above the springs to lower the trailer, or considering a lifting roof design.
Members cautioned that lowering the axle setup must still leave enough suspension travel between the axle and frame...
More...
Jwh92020
Senior Member
Joined
Jun 10, 2015
Posts
620
Location
Oklahoma City
A guy wants me to build him a 5x8 square drop to tow behind his 2023 Honda CRV (150 lb tow capacity). He wants it as light and low as possible. He has a Northern Tool 5x8 trailer. He wants the camper roof no higher than the car's roof - 65", without compromising interior cabin height. The light part I can handle, but the low part is puzzling me. He wants to use 10" wheels and tires. I'm thinking stick with 12", but mount the axle on top of the springs to lower it. This will not be an off roard trailer. It's just for he and his wife to travel coast to coast. Any ideas will be welcomed.
Need to make sure that will leave room between the axle and bottom of frame rails for up travel. Might have to C-notch and reinforce the frame.
Bad things happen to spindles and bearings if the axle hits or rides on the frame. High impact shock test levels of hurt.
I thought about that. I know that there are a lot of pop ups that run 8" and 10" wheels, and even though 12" isn't a huge difference, the lesseser bearing wear seems like a better way to go.
Maybe a two-piece cabin with a roof that can be raised?
Just a thought.....Roger
Is this for efficiency and aerodynamics reasons or storage? See Aerodynamics - One Hundred Years of Missed Opportunities
Lets say the goal is to have 5kw of drag at 55mph (just making up numbers here). Lets say rolling resistance is 1kw and aerodynamics is 4kw. With a squaredrop and hard edges and square back, you might be getting 3kw from the back. Let's say instead you make it 25% taller and that increases the remaining aerodynamic drag from 1kw to 1.5kw. You could reduce the back's aerodynamic drag by 0.5kw fairly easily by adding a 2" radius chamfer to all the edges and making the back 4" narrower than the front part. (I'm spitballing the numbers here) So if the goal is "same drag as squaredrop 65 inches tall" making it that height isn't the only answer.
Bump stop.
Bump stop.
Actually, I think it's a combination of both. He had an old pop up that had 8" wheels that hevpulled around the country wih "no issues" according to him. He figures 10" wheels would be better than 8". He's holding pretty firm on that idea.
Bump stops only work if there is room for them and they are only engaged within their ability to decelerate the axle at the end of its travel when the springs are already heavily conpressed. If the axle has no travel or is already hard into the stops before the springs are compressed the bumpstop won't do enough work, acting more like a solid hard stop. At least that has been my experience with a lowered vehicle that was loaded down to where there wasn't enough suspension travel. Bumping along on the bump stops felt very much like the axle slamming into the frame rails, and that was at very low speed.
I am considering doing this with my Haul Master 5x10 (Harbor Freight), going from 13" down to 8", (23.5" down to 18" diameter) reducing ride height by about 2-3/4". I'm less concerned about bearing wear than clearing driveways. The axle is already over the springs as delivered.
My thinking is that the profile of my shell is too high relative to my lowered car - preventing me from seeing anything over the top of the popup with the center mirror, and my side mirrors don't extend far enough to see in the lane behind me. I'm also thinking it will improve aerodynamics as the extra height at the top is catching significant airflow.
I only have 5" of clearance under the car and don't need the nearly 12" the trailer has at the axle. Weight and speed limits aren't really a concern for me since efficiency with my EV pulling it runs off a cliff over 65 mph.
I thought about only going slightly smaller with a 12" wheel, but that only drops about an inch, which is not enough for the mirror issue. I could also throw on a torsion bar or independent suspension for more drop, but that's quite a bit more money than a set of wheels - of which I could carry a complete spare set and still beat that cost.
