This is the same trailer I’ve been asking about that is sold by Tractor Supply. See discussion here: viewtopic.php?f=35&t=75388Offgrider":d3j55a0v said:I am planning a new trailer build, has anyone heard any feedback on the 5x8 trailer sold on homedepot.com, the trailer is built by Westbrook trailers. It cost 1099.00
Squigie":2ggzw4x9 said:It requires increased power settings to weld, and requires the same safety precautions as normal galvanizing. You're best off grinding the coating off before welding (which still requires normal galvanized safety precautions).
In other words:
Can be done.
Needs more juice.
Toxic.
Extra work.
Paintsalot":17ijva8n said:Offgrider":17ijva8n said:And the 12 inch tires are good, they have a speed rating up to 87 miles an hour
Yes- called Westbrook Trailer- Tires on 5x8 Stirling trailer are rated for 87mph.napoleonbot":i5st41vz said:Paintsalot":i5st41vz said:Offgrider":i5st41vz said:And the 12 inch tires are good, they have a speed rating up to 87 miles an hour
Are you sure? many said the tire suck only 70km, etc...
