MeelisV tear build nr2,5 and now with tow
doorway cuted out to right shape
one door is hanging
need some trimming but looks like working door
Looking good.
Your door handles: is that a mortised lockset that you've built a frame for, or did they come that way ?
I'd love to see a close up of how you mounted them.
hi hi
or almost ho ho ho
there was long long standstill
until now
made second door
last time made galley hatch is now removed because aluminium composite panel was too stiff and spring back
testing bumper (VW T2, LateBay, BayWindow) idea and fender
made new attachments for hatch ribs to hinge
ribs
skeleton
skimming aluminium partly off one side to make panel more flexible
glue and clamp
next step is to find some porthole windows around 12" or 30cm
fasten door handle and hatch handle(s)
make some brackets for fenders and cut fenders to shape
make rear bumper fasteners (modify original brackets to fit trailer)
and then it goes to painter and will be suitable to tow with bus you saw little few pic earlier in garage.
bumper will be similar like in pic before but chrome one with black stripe
https://www.justkampers.com/211-707-311 ... -1979.html
DaddyJeep":oym6gq1t said:
I would love to see more of that paint job on the van. :thumbsup:
because it will be my teardrop tow i will tell you quick story with pics.
5 years ago it was like this, not so bad from far but ...
very bad and rotten frame and all other places, floor, fenders, doors, and ...
after cutting, sandblasting, welding, glass blasting, filler, sanding and painting
the right one is the right one
miles and miles tape
and then
painting and painting
after painting and before clearcoat
clear coat on the way
there is now 6 times 2 layers clear its total 12 layers clear
and now there is lot of work but it back together
some details are back in place and some new found their place
lot more pics in there
http://thelatebay.com/index.php?threads ... aze.76427/
I stumbled upon this egg again in the garage.
So I rolled it out of the corner, wiped off the dust and looked at what had been done the previous times, what had been planned and what could be done
Then I replaced the hubs with axles and rims,
I put the fender in about the "right place" and I also cut into the arch.
In addition, since I was already cutting, I also made window holes in the doors and tried the windows in front.
When I finally put the fender on the body, I found that the wheel couldn't be changed because it wouldn't fit in between, so I had to make another cut. I then made the arch larger and rounded the corners, which gave a much nicer result and made it possible to change the wheel.
