Meet "Final Meridian": 7x7x16+2 Cargo Conversion
Thread Summary
Summarized on:
Original Member Title: Meet "Final Meridian": 7x7x16+2 Cargo Conversion
A member introduced “Final Meridian,” a 7x7x16 plus V-nose Quality Cargo trailer conversion being built as a stealth exterior camper with a Romani Vardo-inspired interior. The build has become more urgent after medical issues, disability, job loss, and the possibility that the trailer may need to serve as a practical lifeboat while work and housing plans are uncertain.
Progress so far has focused on insulation in Sacramento heat, including ceiling insulation, spray foam in hard-to-reach...
More...
Looking forward to seeing your electrical system install. Keep up the good work.
Thanks, I slowed down on that for a day or two while I got the heater in. I'll finish hopefully making it not look quite so hideous when I get on the road. I'm planning to head to Quartzsite this year, so I'll have some time and space.
I confess it's ugly, but it at least seems to power up and act like it's doing the right thing. 8000 BTU diesel heater inside that steel box.
It's vented near the bed area and the return is in the nose. along with the controller. Everything else is contained outside.
It's been a while since I've posted, I guess, but there's been a handful of changes. I really do need to stay in that ladder. I should do that today.
There is a black pipe bar that goes across the bed frame and the ladder fits into it now. When not in use, the ladder hangs from that bar out of the way. It at least holds the ship ladder stable now, which is nice. I had been wedging it between the OSB and 2x4 frame
[edit]
Oh yeah, there was a scary change that wasn't small. Cutting a 14 inch hole in the roof.
Reversible maxx-air fan is now directly over the kitchen area. It's framed in to match with stained 1x3
Once I got that curtain area shutting off the storage and the dresser underneath the bed, there was just room enough to put my little fake fireplace in. I don't plan on using it for heat, but the flickering fake flames will be nice.
It's just place holding here. I'm going to build a faux hearth for it. That'll raise it up and give it a little more presence.
I was really happy when I discovered I'd be able to fish that old thing out of the garage and use it. Feels like it should be in here.
Oh hey look, it's almost real. There's food in the pantry!
Okay, sort of food, but we have a plan for that.
There's also a plan for the fugly fridge. I'm going to wrap it in rose gold vinyl for the moment, but as I collect stickers on the road, I will cover it like a steamer trunk.
Most fugly stuff is being hidden behind Shoji screens, I like that air conditioner, but it just wasn't practical with where the fridge was.
Now that all the furniture is in, I really need to go weigh the tongue again too. This trailer is really right on the edge of being a lot for my truck.
I have a diesel heater that works very well for me.
However, the white plastic fuel tank, like the one you have, is notorious for failing after a relatively short period of time, especially if exposed to sunlight and/or vibrations.
You might want to Google the question: “are the standard fuel tanks that come with a typical Chinese diesel heater notorious for failures?”.
I've been a little concerned about the likely lack of UV resistance of that thing. I am more than pleased to take suggestions for replacement tanks. Please and thank you? @featherliteCT1
I use the $70 Harbor Freight 5 gallon metal jerry can. However, I replace the fragile gas cap with the replacement cap depicted below (the caps are available in different colors) from Amazon.
5 Gallon Jerry Gas Can
On the other hand, I have read that the RotopaX plastic container is a good choice … but I have never used one. Available on Amazon … a bit pricey … but with standard Amazon 30 day return policy. They also come in 2 gallon size. Again, I would replace the fragile cap.
Hope this helps.
Hope this helps.
So are you drilling in the feed nipple or how are you feeding fuel from it
I'm very interested, thank you.
I'd be inclined to go get an actual jerry can from a surplus place.
Like this $9 metal fuel standpipe, cut to proper length. I drilled a hole in my plastic fuel cap instead of drilling a hole in the metal jerry can itself. I have one unmodified cap I use when traveling with a plastic stopper cap on the fuel line running to the heater. Then switch to the modified cap and reconnect the fuel line to the standpipe when I want to fire up the heater.
However I think most people drill a hole in the metal can.
Amazon.com
Pretty sure red can is color coded for gasoline and yellow is color code for diesel. Might want to research this before purchasing. Just saying.
Maybe yellow is kerosene and green is diesel, I don't remember, but rotary molded plastic cans should also include permanent molded in labels for fuel type. Research needed.
View attachment 2500416Amazon.com
Thank you, I picked up a metal surplus jerry can to replace it. I just haven't gotten around to it.
I've been very poor at updating this, but things are getting much closer than I would like. I don't know if I'm going to make it on time. I may have to try to negotiate for a few more days.
And before anyone wonders, yes I did finally get around to staining the ladder.
100% of current focus is on finishing the electrical system.
9.2kWh of battery, 1200wts solar, 3k+500wts inverters, 2500/2000wts gas generator
The 50 inch monitor is behind the antique gold curtain.
I like that!
I guess that for all-in, which my system as described, is (I have 800 watts on the roof and 400 watts on the ground) I have to add another 1800/2700 watt inverter or something like that. The ground 400 feed an EcoFlow 2 battery system, or they feed a second 40A MPPT that feeds the big house batteries. The 60 amp MPPT is fed by the 800 watts on the roof. That also feeds the 500+3000/6000 inverter charger.
Seems convoluted and there is a little bit of waste to acknowledge, however, I am also looking for redundancy.
Don't judge yet. This is a work in progress today. It's not completed. This is only the DC board. The AC board will be going up tomorrow.
Not pictured is a 400 amp class T fuse that's about six inches from the battery. There's a little few inch pony wall with protection built right next to the end of the battery bank and a 9 inch 4aught connecting it.
You may already know this, but never open or close one of those automotive type breakers while current is flowing through the breaker, especially if it is a non Blue Sea breaker or equivalent. To do so, would likely damage the internal breaker contacts.
If you have not already done so, you might consider putting your system under a stress test by flowing the maximum amount of current for which your system is designed, for a reasonable period of time, through the system, to see if any of the breakers, terminals, switches or wires get excessively warm to the touch. If any point show signs of heat, you’ll know you have a problem at the point where the heat is generated.
You have come a long way. Keep going!
These are marine and with the exception of one small one for the little 500 watt inverter, they're all blue sea. The little one is Red Wolf.
Thank you!
In general, I would turn off the system with the 800 amp shut off.
The only time those are going to open is not when I open them, but when they're open from being over heated, which is hopefully never. But yes, they are thermal curve marine type breakers. Same thing I use(d) on my boat.
Once I activate that system, I'll load it as much as I can, but I have a thermal flir camera. I don't really plan on having a load bigger than maybe my inductive cooker on it. Or a bit longer with the oven, I think it's less wattage though.
In theory, the house AC could pull quite a bit off of it. If catastrophic things happened... The main is a 32 amp 120v breaker, and then my distribution panel has two 20s and three 15s. Shore power is a 30 amp 120 rv plug and I also have a 20 but that doesn't go through the inverter. The inverter functions as a transfer switch.
The two dedicated 20A 120s go to the kitchen appliances and to the inverter type air conditioner. The 15 amp circuits, one goes to lighting and the other two go to plugs, one circuit down each wall.
