DrewsBrews
Senior Member
- Joined
- Jul 13, 2015
- Posts
- 478
Hi all. This is a continuation of The Snuzie Cube, however that project went south. I am taking the frame I built and going a different direction. I figured it would be best to start fresh with a new thread to be less confusing.
So I have a 5ftx10ft frame with 1400lb of spring rating to work with. I've also got a rooftop tent to mount on it. The tent is a clamshell type: A hard floor that mounts to a sturdy car roof rack. You would normally mount it so the tent opens off to the side of the vehicle. It is a large version 6ftx4ft that opens to 6ftx8ft with an included 2" Cali king size mattress (roughly).
The plan: To build an aproximately 5ft(w) x4ft(d) x2ft(h) box up towards the front of the frame with hatches for storage and possibly an A/C unit. Then, behind that (the rest of the 5ftx6ft area of the frame) will have composite decking to act as a small flatbed for bringing large things that wouldn't fit in a car and be a pain to get up in a truck bed if that is the tow vehicle. The tent will be mounted on top of the storage box up front and open towards the rear. This gives a small 2ft step out to the decking (will replace tent ladder with a smaller 1-2step one). And will have a small step stool to step off the trailer from there. I also have a roof rack mount style awning to mount somehow to the side (with zip on enclosure if needed).
The trailer is 5ft wide, while the tent is 6ft. So the tent will hang over the sides aprox. 6".
The trailer frame is not yet registered. I will be doing so as a "self built". Here in Ohio, utility/cargo type non-commercial trailers under a certain weight are not titled, only registered. However camper trailers are titled (If it encloses a mattress it is considered a camper). That was always an iffy part for me during the previous project. I heard nightmares of trying to get a self built camper titled in Ohio. At that time I was hoping to squeeze through the cracks by registering the frame as utility/cargo and building the rest on top of it.. not unlike what people do for teardrops on Harbor freight frames (though I was not happy with the idea). Fortunately It never got to that point, and this time around it basically will be a utility trailer with a small enclosed cargo area and tongue box. The tent is a seperate item. Makes it alot more cut and dry come inspection time.
