DrewsBrews
Senior Member
- Joined
- Jul 13, 2015
- Posts
- 478
I started thinking about the shore power wiring again. I don't know why I didn't think of this before, but I could test the GFCI power strip to see if it has overcurrent protection...
I wired my house with 20A circuits. So anything with 15amp overcurrent protection should trip first. I have two portable electric heaters I keep in storage for emergencies. The current draw of both should overload a 15A circuit. I connected them to the power strip along with a light as a visual cue showing power was cut. Sure enough after about a minute or less it cut power. No signs the cord or anything else was overheating. Turns out the power switch on the strip realy is an overcurrent protection type. I reset the power switch to the on position and tested again. Same result.
Mega cool, that simplifies things! The cord on the power strip is 6ft so I can just run it to the shore power hookup box and use it's plug to connect the extension cord out to the power pole. Easy peasy! That way my core shore power wiring is literally just a protected power strip. If it goes bad I can quickly bypass it with something from the store, no tools needed. This is some real ASMR stuff for me! I love condensing down and streamlining systems like this!
To reiterate, it is this "Woods" brand model that I tested and will be using:
Looks like the same unit is sold under multiple brands too. I may order another to keep as a spare.
. Still deciding how I want to finish that.
