If you need them, carriage bolts are available in grade 8 strength. Some farm implements use them. BTW, it isn't that hard to square a round hole in a piece of steel. Use a square file, and the job is a bit easier. There are also plow bolts which go into a squared or keyed bevelled hole. I'm not sure how you'd make the bevelled hole on the inside of a tube.... The strongest grade of T-slot bolts would also work, you want 150,000 psi or stronger strength. You would need to file your initial round hole into a slot to use them.
Wow, Fastenall only has one grade 8 carriage bolt. McMaster-Carr didn't have them, only up to grade 5. Hum, looks like Fastenall has them under "Shaker Screen Bolts". Very slightly different head shape than a typical carriage bolt, but they still have the square shank for locking into a square hole. Hum, I don't see any anti-rust coatings, so thread lock them to keep the moisture out of the threads, and then paint over them.
If I had reasonable access for a box end wrench to access the bolt head from the tube end, I'm not sure I'd use a carriage bolt. If for some reason the square hole gets stripped it could be very hard to remove the bolt. Grinding through a grade 8 nut and bolt is hard work. I bet most frames are only mild steel and not hardened steel or high tensile steel which I think would be a minimum for use of a grade 8 carriage bolt. That square shank is small and the area it bites against is also small.
Fred
here on the forum. Every email update with photos he's sent me is like Christmas morning. And not only will my trailer be fantastic, I get to see what the country is like east of WA, OR, and CA. It's going to be a great adventure driving out to Michigan to pick it up.
Fred
